    Access WebUI directly over SPI? (Duet2 Ethernet)
    • snail-fleetundefined
      snail-fleet
      Is there a way to connect to a Duet2 board directly over SPI with a Raspberry Pi? I had seen a mention of this intention elsewhere, but can not find any additional details.
      Long story short, I accidentally applied 5v across a couple of the Ethernet pins and it appears I have hosed the Ethernet module. I am looking for any way to connect up to the printer (ideally to webUI) so I can continue printing until a replacement module arrives.
      Any suggestions would be greatly appreciated.
        It is possible to replace the network module with a connection to an SBC and then use the SBC for network and SD card functionality in the same way it's possible with the Duet 3.
        See this thread: https://forum.duet3d.com/topic/17203/duet-2-ethernet-and-sbc
