    duetWiFi does not return from emergency stop sequence.
    1
    139
    • c310undefined
      c310
      i have connected mushroom emergency stop button and it works when hotend is cold and 24v water pump is off (being connected and feed from the board)...
      i also have PS_ON button to switch printer ON.
      however, once hotend becomes hot and that triggers water pump, after emergency stop duet is no longer able to return itself to operations. reason - water pump sucks all power and PS_ON goes down before board reboots.
      what can i add to the schematics in order to keep board powered for 5 seconds?
