    Solved Duet 0.8.5 firmware installation
    Firmware installation
    • Dave Parry
      Dave Parry last edited by Dave Parry
      I'm not sure if my duet is fried, but I had to erase and reset my duet 0.8.5 and I have tried installing 2.05 but at the moment it won't do anything, no ethernet connection and no movement even using the display. I cant remember what the latest software I can install is. I think I had Duet2Firmware-2.05.1 installed (and 1.15 on the paneldue display). Is this correct and can I just install this or do I have to install Duet firmware 1.26.1 first? I will try again later today using Fallback procedure #3 (https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware_(Legacy)).
      Thanks.
        dc42 administrators @Dave Parry last edited by dc42
        @dave-parry, the latest firmware for the Duet 085 is version 1.26.1, but it is the RepRapFirmware.bin file in the 2.05.1 release. Is that the firmware file you installed?
        Dave Parry 1 Reply Last reply Reply Quote 0
        • Dave Parry
          Dave Parry @dc42 last edited by
          @dc42 It was in the 2.05 bin, but I thought I used the combined file. Will use the 1.26.1 one and let you know what happens.
          • Dave Parry
            Thanks David, All sorted now. I think I may have used the 2.05 combined file and also the backup config file I used had an old router address on. Anyway back up and running again.
