    No movement when position command sent without G0/G1
    CNC
    • PARRS
      PARRS last edited by
      Currently running dsf 3.2.2
      Is anyone else having issues with no movements taking place when a G0/G1 command is left out? (G1 command was used in the previous line)
      I remember this working with past versions but can't seem to get it working. For example a code would be:
      G1 X250
      X300
      The carriage would move to X250, but then no movement taking place after. I get a "check mark" X300 in the console but there's no physical movement or position update in the controller...
        dc42 administrators @PARRS last edited by
        RepRapFirmware supports commands in that format, but only when switched into CNC mode using M453. I'm not certain whether DSF on the SBC does, I will find out.
        PARRS 2 Replies Last reply Reply Quote 0
        • PARRS
          PARRS @dc42 last edited by
          Thanks! I am currently in CNC mode. Tried with a tool selected and no tools selected which results in the same "check mark X###" making it seem like it works.
          • PARRS
            @dc42 Any news on this?
              @chrishamm is looking at it.
