    Separate Accel / Decel Rates
    Firmware wishlist
    363
    • CCS86
      CCS86 last edited by
      After doing a lot of testing to find ideal accel and jerk rates for each axis, I realized that even with ideal printing acceleration set, your travel acceleration can still impact your outer wall at the seam.
      Sometimes the travel move is short, when seams are aligned. But other times a longer travel move lands you right at the start of your external wall. This can cause ringing in your outer wall.
      The best thought I have had so far, is to be able to define a separate deceleration rate.
      deckingman dc42 2 Replies Last reply Reply Quote 4
      • CCS86
        @dc42 Thoughts?
        • deckingman
          deckingman @CCS86 last edited by
          @ccs86 said in Separate Accel / Decel Rates:
          Is M204 no good? https://duet3d.dozuki.com/Wiki/Gcode#Section_M204_Set_printing_and_travel_accelerations
          Although acceleration and deceleration rates are the same for each move type (print or travel), it would still give you the ability to set different values for printing vs travel. So for example, if you wanted to use a lower/higher travel deceleration than that use for printing, you could do it with M204. Admittedly, the travel acceleration would also be lower/higher but would that matter?
          • CCS86
            No, M204 doesn't provide the benefit I am asking for.
            Typically, you use higher travel acceleration than printing acceleration. This means that on the travel move that takes you to the external perimeter, you get full travel acceleration, which can cause ringing in the print head, just as you begin the outer wall.
            • bot
              bot last edited by
              Yes I agree completely. I suggested similar here.
              *not actually a robot
              CCS86 1 Reply Last reply Reply Quote 0
              • CCS86
                CCS86 @bot last edited by
                @bot said in Separate Accel / Decel Rates:
                Yup, you noticed the same thing that I did.
                I think that your suggestion could potentially work better than defining a mandatory deceleration rate: if a travel move is followed by a print move, apply either the print acceleration rate, or even a new decel rate. This would allow a string of back to back travel moves, to use the higher travel acceleration (like when "avoiding printed parts").
                It's kind of a tricky problem, of when / how to apply this. You could argue, that you only need slower decel when making the move to the external perimeter start point. But, you could also argue that a travel move to any wall needs it, since that ringing could still technically "print" through the external wall (though muted a bit). Then, you have the case of non-connected, solid infill; where you have travel moves connecting every infill line. Would a reduced decel rate cause slowdowns, or are these moves so short that it is a total non-issue?
                bot 1 Reply Last reply Reply Quote 1
                • bot
                  bot @CCS86 last edited by bot
                  Great thoughts. IIRC, if we significantly change any of the acceleration on a print it definitely has a surprising impact on print time.
                  I've played with modifying PrusaSlicer to see how the seam can be improved. I think there is some room for improvement. I tested out my other zany ideas and they were not beneficial, but my current thinking on getting the best seam would be: decelerate gently into all of the perimeters, because of the 'print-through' of errors to the external, and also to align the perimeter seams, but offset them slightly for each subsequent perimeter going out from in. This way, we can minimize the effect of the "print through." This last part is something I had in mind to test.
                  E.g. of the alignment of seams:
                  [Edit: Jeez, sorry for the huuuge image and taking this topic off track. This was a long way of saying I think customizing deceleration for certain scenarios could help. We must also remember dc42 has a planned rework of the whole motion system in the mix. Perhaps this is a good time to bring this up, but also maybe it's too much to throw into the first iteration of the new system so it could be added after/with a refactor for a v1.1.]
                    dc42 administrators @CCS86 last edited by dc42
                    The acceleration will also cause ringing, and some of that ringing will still be present after the deceleration. How much will depend on the length of the travel move and how damped the ringing is. For example, suppose in your print you can see significant ringing lasting for a distance of 5mm from a corner, when printing perimeters at 50mm/sec. Therefore the ringing persists for 0.1sec. If your travel moves are at 200mm/sec then after travel moves up to 20mm long you would still see an effect from ringing caused by acceleration. For longer travel moves, there would be some benefit to allowing higher acceleration. In practice most prints have both long and short travel moves. So the travel acceleration would need to be adjusted depending on the move length.
                    Input shaping will be effective at reducing ringing without having to reduce acceleration and deceleration as much.
                    CCS86 1 Reply Last reply Reply Quote 1
                    • CCS86
                      CCS86 @dc42 last edited by
                      Fair enough. Input shaping is probably the best first pass at all these resonance issues. I'm just worried my Maestro will miss the party.
                      Any ETA shaping up for the first beta?
