    Duet 2 Wifi Dual z
    • TheBiologist
      TheBiologist last edited by
      Good Evening all,
      I have and Ender 5 that I recently converted to dual z axis with a Duet Wifi 2 running it. I had a great config file running before but I do not understand the guide. I have the second motor hooked up to ZB motor connection. I am using a bl touch for an endstop. My latest attend resulted in the Z motors spinning in opposite direction regardless of changing in the config file. Here is my config, bed, homeall, and homez files. Thank you in advance
      M550 P"Ender 5" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P3 S0 ; physical drive 3 goes forwards
      M569 P4 S0 ; physical drive 4 goes backwards
      M584 X0 Y1 Z2 E3:4 ; set drive mapping
      M350 X32 Y32 Z32 E32:32 I0 ; configure microstepping without interpolation
      M92 X159.875 Y160.978 Z1598.13 E204.15 ; set steps per mm
      M566 X600.00 Y600.00 Z60.00 E300.00:60.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z600.00 E600.00:600.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z200.00 E4000.00:200.00 ; set accelerations (mm/s^2)
      M906 X850 Y800 Z700 E800:700 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X225 Y211 Z300 S0 ; set axis maxima
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P9 C"^zprobe.in" H5 F6000 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P0 X-55 Y-13 Z1.697 ; set Z probe trigger value, offset and trigger height
      M557 X0:170 Y0:191 S20 ; define mesh grid
      M106 P0 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
      M950 F2 C"fan1" Q500 ; create fan 2 on pin fan1 and set its frequency
      M106 P2 S0.3 H-1 ; set fan 2 value. Thermostatic control is turned off
      M563 P0 F0 ; define tool 0
      homeall.g; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 24 2021 17:43:04 GMT-0500 (Central Daylight Time)
      G91 ; relative positioning
      G1 H1 X-230 Y-216 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-230 Y-216 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G90 ; absolute positioning
      G1 X55 Y13 F6000 ; go to first bed probe point and home Z
      ;G91 ; relative positioning
      ;G1 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      homez.g; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 24 2021 17:43:05 GMT-0500 (Central Daylight Time)
      G1 X55 Y13 F6000 ; go to first probe point
        If you're using the Za and Zb connectors it's a single driver running the motors. If one is going in the wrong direction, flip the connector 180 degrees to change it's rotation.
