    some questions about configuration
    Using Duet Controllers
    404
    • cosmowaveundefined
      cosmowave
      Hello everybody.
      i have some questions about my configuration. I'm using a Duet2 Ethernet with RRF 3.2.2
      1. I d'like to have a temp controlled MCU-Fan, my config is looking like this:
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency (MCU fan)
      M106 P1 T25:60 L0.4 X1.0 H100:101:102              ; set fan 1 value. Thermostatic control is turned on (MCUtemp start @25°with40%, full @60°)
      Why is this not working? The Fan itself and the cabeling is ok, but it turns not on with MCU temp > 25°. Is there a wrong programming?
      1. My printer has a watercooled hotend with flow detection. I have defined a pin1 for triggering "trigger2" like this:
      M950 J1 C"!^E0STOP"				; Input 1 uses e1Stop pin, inverted, pullup enabled (FlowSensor)
      M581 P1 T2 S0 R0				; invoke trigger 2 when an active-to-inactive edge is detected on input 1, anytime
      The trigger is working, but on falling and rising edge of the signal. This is not a big problem, but i d'like to know why! With this code, it should only trigger at falling edge!?
      1. In the "trigger2.g" itself, i d'like to call two different macros according to machine state.
        The "trigger2.g" looks like this:
      if state.status="idle"
      	M98 P"0:/macros/NoFlowIdle"
      else
      	M98 P"0:/macros/NoFlowNotIdle"
      With this code, allways the "NoFlowNotIdle" macro is called, although the Duet is idle! Why? And what are the possible states of the duet? Is there a list?
      Thank you very much for your help. And sorry for my english...
      Mankati FSXT+, DeltaTowerV2, E3D MS/TC
      droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @cosmowave
        @cosmowave For (1), you're using the RepRapFirmware 2 notation for MCU temperature. See https://duet3d.dozuki.com/Wiki/Mounting_and_cooling_the_board#Section_Notes
        For (2), I'm not sure why it triggers on rising and falling edge, when you've set S0. @dc42 ?
        for (3), it's because the status changes to 'busy' when you run a macro, even if the printer is idle (at least it does when I just tried it out). I think the following document lists the main runtime states as idle, busy, printing, paused, halted, resuming and changingTool (though may be slightly out of date): https://duet3d.dozuki.com/Wiki/Status_Responses
        Again, @dc42 may be able to elaborate on all the different states and exact wording reported for each state.
        cosmowaveundefined 1 Reply Last reply Reply Quote 0
          cosmowave @droftarts
          @droftarts thanks for your explanation.
          For (1), you're right! I will try it like this and check it today evening:
          M308 S3 P"mcu-temp" Y"mcu-temp" A"MCU"    ; configure sensor 3 as mcu-temp on pin mcu-temp, show temp in graph as MCU
          M106 P1 T25:60 L0.4 X1.0 H3               ; set fan 1 value. Thermostatic control is turned on (MCUtemp start @25°with40%, full @60°)
          for (3)
          i think, my coding (with status.state) is not the best for option for switching between "no print is running" and "a print is running"!
          Do you know which variable i can take to make a switch if a print is running or not?
            dc42 administrators @cosmowave
            @cosmowave said in some questions about configuration:
            Contact bounce, perhaps? I can look at adding a debounce option to M950 with J parameter.
              cosmowave @dc42
              @dc42 hmmm, that can be. Its an old relais switching this input.
              I try to measure it with my scope...
              Do you have an idea about my other problem described above?
              dc42undefined droftartsundefined 2 Replies Last reply Reply Quote 0
                @cosmowave, I think there are several values in 'job' that you could test, such as job.duration and job.fileName.
                  cosmowave @dc42
                  @dc42 i can't see job.duration in the object model! Does it exist?
                  i think, job.layer can be a good candidate?
                    @cosmowave Or you could flip the macro around so that it checks if it's not printing:
                    if state.status!="printing"
                    else
                      @droftarts yes, that's an option.
                      But i'm not sure, if the state is changing to something other than "printing" during a print!?
                        I can see job.duration in the OM browser, it's null because no print is running. I am running firmware 3.3beta3.
                        job.layer is not reliable in firmware 3.3 because we've given up trying to second-guess which layer is printing, unless there are layer comments in the GCode file.
                          cosmowave @dc42
                          @dc42 said in some questions about configuration:
                          Is it possible to add a debounce option?
