    Duet3D setup
    • NRussundefined
      NRuss
      I have tried to set up my Duet 3D board, but have been unsuccessful. When using the LCD touchscreen on the printer it is unable to connect to the wifi. When I then tried to plug it into the computer to set it up by following this: https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
      it was not recognised as an input.
      The board lit up when connected, so power was drawn from the USB connection. I have tried multiple cables, and multiple ports on my laptop, but no change.
        droftarts administrators @NRuss
        @nruss What 'LCD touchscreen' are you using? Is it a PanelDue, or something else? It sounds like the wiring may be incorrect and shorting out the power to the Duet.
