    Accelerometer plugin small bug(s)
    Duet Web Control
    • SIam
      SIam last edited by SIam
      I have 5 different CSV files if I click on the first entry it will be opened but the highlighting is on the 5. Entry when i click on the second CSV the highlighting is on the 4. Entry and so forward..
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
      SIam 1 Reply Last reply Reply Quote 0
      • SIam
        SIam @SIam last edited by SIam
        if i go to Sampling Rate then will popup a tooltip witch says the value must be smaller or equal 1000 should this not be 1361? The same with the end slider it goes only up to 999
        chrishamm 1 Reply Last reply Reply Quote 0
        • chrishamm
          chrishamm administrators @SIam last edited by
          @siam Thanks, I'll fix that. The correct range for the sampling rate should lie between 400-6000Hz.
          Duet software engineer
