Solved Stack overflow after heater tuning
I cannot tune my heaters as every time I do, I get a stack overflow error (except on some rare occasions when it just works, which is odd).
This occurs right at the end of the last cycle:
No heater config is printed for me to put in config-override.g so the entire tuning was a waste of like 15 minutes.
Here is the full M122 dump after the reset caused by the error:
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet Ethernet 1.02 or later + DueX5 Board ID: 08DGM-9T6BU-FG3SJ-6JTDJ-3SN6P-9SYZG Used output buffers: 3 of 24 (15 max) === RTOS === Static ram: 23460 Dynamic ram: 71864 of which 24 recycled Never used RAM 16732, free system stack 195 words Tasks: NETWORK(ready,167) HEAT(blocked,308) DUEX(blocked,31) MAIN(running,449) IDLE(ready,20) Owned mutexes: === Platform === Last reset 00:00:10 ago, cause: software Last software reset at 2021-04-27 21:09, reason: StackOverflow, Move spinning, available RAM 16732, slot 2 Software reset code 0x4104 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80e BFAR 0xe000ed38 SP 0x2001ffc4 Task HEAT Freestk 30309 bad marker Stack: 200025d0 20002604 004554a5 2000460c 00454ad5 2000262c 2000460c 00000000 00f00000 e000ef34 c0000000 2000468c 00454c13 00454984 61000000 ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 36.6, current 37.2, max 37.4 Supply voltage: min 24.3, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 0, standstill, SG min/max not available Driver 1: position 0, standstill, SG min/max not available Driver 2: position 0, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0, standstill, SG min/max not available Driver 6: position 0, standstill, SG min/max not available Driver 7: position 0, standstill, SG min/max not available Driver 8: position 0, standstill, SG min/max not available Driver 9: position 0, standstill, SG min/max not available Driver 10: position 0 Driver 11: position 0 Date/time: 2021-04-27 21:09:13 Cache data hit count 14053254 Slowest loop: 6.19ms; fastest: 0.22ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.3ms, write time 3.8ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 11.32ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 Interface state active, link 100Mbps full duplex === DueX === Read count 1, 5.53 reads/min
@vcapra1, thanks for your report. This may already be fixed in firmware 3.3beta3, but if not then I will increase the Heat task stack size further.
@dc42 Thanks for your reply. It still seems to be an issue in 3.3beta3:
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3beta3 (2021-04-22 16:27:28) running on Duet Ethernet 1.02 or later + DueX5 Board ID: 08DGM-9T6BU-FG3SJ-6JTDJ-3SN6P-9SYZG Used output buffers: 1 of 24 (16 max) === RTOS === Static ram: 23156 Dynamic ram: 73736 of which 0 recycled Never used RAM 17524, free system stack 204 words Tasks: NETWORK(ready,24.1%,216) HEAT(delaying,0.0%,310) Move(notifyWait,0.1%,214) DUEX(notifyWait,0.0%,24) MAIN(running,74.0%,441) IDLE(ready,1.8%,19), total 100.0% Owned mutexes: === Platform === Last reset 00:00:11 ago, cause: software Last software reset at 2021-04-28 19:56, reason: StackOverflow, GCodes spinning, available RAM 17524, slot 0 Software reset code 0x4103 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80e BFAR 0xe000ed38 SP 0x2001ffbc Task HEAT Freestk 28713 ok Stack: 20003ebc 20003ef0 0045acf9 00000000 20005958 000000c8 0045a385 20003f1c 20005958 00000000 00f00000 e000e000 c0000000 00000002 0045a4c1 0045a238 21000000 ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 32.9, current 33.4, max 33.8 Supply voltage: min 24.3, current 24.4, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Driver 0: position 0, standstill, SG min/max not available Driver 1: position 0, standstill, SG min/max not available Driver 2: position 0, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0, standstill, SG min/max not available Driver 6: position 0, standstill, SG min/max not available Driver 7: position 0, standstill, SG min/max not available Driver 8: position 0, standstill, SG min/max not available Driver 9: position 0, standstill, SG min/max not available Driver 10: position 0 Driver 11: position 0 Date/time: 2021-04-28 19:57:09 Cache data hit count 455436309 Slowest loop: 5.58ms; fastest: 0.17ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.3ms, write time 30.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === DueX === Read count 1, 5.10 reads/min === Network === Slowest loop: 13.08ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 Interface state active, link 100Mbps full duplex
@vcapra1 Actually I just realized the stack size change was committed after 3.3beta3 was released, I'll try compiling the latest version and see if it helps
Ok with the latest updates it seems to be working, thanks!
