Bondtech DDX v3 and Duet Mini hotend temperatures fault values
Dear all, I need your help.
I have installed the new Mini duet 5+ but the readings in the hotend heater 1 is reading 1050 degrees Celsius. Bed sensor is working properly. I have a Bondtech DDX v3 in the Ender 6. I have followed all the guides available from the Ender 3 Pro and other forums from Facebook and Bondtech but is not clear from where is comming my problem. I have access to the
control panel via wi-fi in my Mini Duet, I am able to follow some of your tips or suggestions. Here is the config file.
-Do you think I am using the wrong value for the thermoster?
-Could be possible that my Bondtech is not compatible with the mainboard Duet?
-Probably the sprayboard used in the Ender 6 it is causing the error in the sensor in my Thermistor?Thank you
; Configuration file for Duet 3 Mini 5+ (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Apr 29 2021 21:09:38 GMT+0200 (Mitteleuropäische Sommerzeit); General preferences
M550 P"My Printer" ; set printer name
M669 K1 ; select CoreXY mode; Network
M551 P"Javcab1970!" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0.1 S1 ; physical drive 0.1 goes forwards
M569 P0.2 S1 ; physical drive 0.2 goes forwards
M569 P0.3 S1 ; physical drive 0.3 goes forwards
M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E9000.00 ; set maximum speeds (mm/min)
M201 X1500.00 Y1500.00 Z20.00 E1500.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X250 Y250 Z400 S0 ; set axis maxima; Endstops
M574 X2 S1 P"io5.in" ; configure active-high endstop for high end on X via pin io5.in
M574 Z2 S1 P"io2.in" ; configure active-high endstop for high end on Z via pin io2.in; Z-Probe
M558 P5 C"^io3.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
G31 P500 X45 Y5 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin temp0
M143 H0 S100 ; set temperature limit for heater 0 to 100C
M308 S1 P"temp1" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin temp1
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M143 H1 S260 ; set temperature limit for heater 1 to 260C; Fans
M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
M106 P0 C"PartCool" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
M106 P1 C"Hotend" S1 H1:0 T45 ; set fan 1 name and value. Thermostatic control is turned on
M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency
M106 P2 C"CaseFan" S1 H1:0 T45 ; set fan 2 name and value. Thermostatic control is turned on
M950 F3 C"out6" Q500 ; create fan 3 on pin out6 and set its frequency
M106 P3 C"Leds" S1 H-1 ; set fan 3 name and value. Thermostatic control is turned off; Tools
M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
T0 ; select first tool -
