    Duet 3 Mini 5 web control issues
    Firmware installation
    • ComedianTF2
      ComedianTF2 last edited by
      Hi All, I got a new Duet 3 Mini5+, and I'm having issues with getting to the web control, when I browse to the IP address, I get the following error:
      Your Duet rejected the HTTP request: page not found
      Check that the SD card is mounted and has the correct files in its /www folder
      I checked and re-uploaded the DuetWiFiServer.bin on the SD card in the sys folder, it seems to not be able to find it when I send M997 S1, giving me the following error: Error: M997: File DuetWiFiServer.bin not found
      I have also reformatted the card, but no luck
      When I run M122, it seems to recognize that I have the SD card installed:
      RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: W7QA8-8296U-D65J0-40KMW-M403Z-Z9899
      Used output buffers: 1 of 40 (13 max)
      === Storage ===
      Free file entries: 10
      SD card 0 detected, interface speed: 0.2MBytes/sec
      To exclude the SD card as a possible cause of issues, I have also taken the microSD card from my Duet 2 WiFi, which I know works, and it it giving the same issues.
      What would be the next thing to check?
        dc42 administrators @ComedianTF2 last edited by
        @comediantf2 please ask your supplier to replace your Duet 3 Mini, quoting this post as authorization. We have had a few instances of intermittent SD card communication in the first production batch.
