Failed to Start Duet Control Server SBC
Im using the supplied one. When i receive the Board its working fine, then i make a update over DWC ( zip file), now its not working. I Flash the pi some times (try Lite and normal) but its impossible to Start the Duet Control Server.
I do all how its here explaned:
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware -
@ivery86 Did you flash RepRapFirmware 3.2.2 on the Duet controller via bossac? Can you ensure there is no SD card in the Duet?
The First Time i was updating over DWC. But i try severel times to Flash over Bossa. I try 3.1, 3.2, 3.3
Yes without sd in the duet3
Is it possible to Check the cable working Fine? Because When i Start without connected to the duet, its looking the same
Now I have tried it from step one without duetpi the Problem is, im not able to Set the buffersize, i dont have the authorization
@ivery86 You do not need to set the buffer size if you are using DuetPi (or the supplied SD card in the Pi). I suggest you take a microUSB cable, connect the Duet to your PC, and send M122 to it.
If you are using DSF 3.2.2 as seen in your screenshot, you should be using RRF 3.2.2 as well. See here for further troubleshooting.
I checked it, its the 3.2.2 RRF. Now i order a new Ribbon cable, to Check if its the problem. Thank your for your help
Now i have checked the Resistence of the ribbon cable and its all ok. The First Time After i configurate the duet and the sbc (it worked) i plugged it wrong way and Powered it. is it possible something is damaged?
I bought a new RPI, now it works Fine
@ivery86 said in Failed to Start Duet Control Server SBC:
Interesting. Thanks for letting us know.
