    Activation sortie OUT1
    • Nadège Andréundefined
      Nadège André
      Hello
      I have a duo 3 6HC and I would like to put a solenoid valve on OUT1.
      I wish I could turn OUT1 on ON / OFF while printing, but I don't see how.
      I thought I would define a Gpio port with M950 and then activate it with M42, but then how to do an ON / OFF on this output?
      Thank you in advance for your help!
        dc42 administrators @Nadège André
        @nadège-andré that is correct. If you choose gpOut pin 0 for this purpose then the commands would be:
        M950 P0 C"out1" ; define the port
        M42 P0 S1 ; turn the valve on
        M42 P0 S0 ; turn the valve off
        Nadège Andréundefined 1 Reply Last reply Reply Quote 0
          Nadège André @dc42
          @dc42 said in Activation sortie OUT1:
          Super merci je vais essayer de suite!
