    Resume after Power Failure - Quick question
    • tsitalon1
      tsitalon1 last edited by
      Hey guys,
      Following the below link, I have everything working except one thing:
      https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure
      The only portion that is not working is lifting the Z axis on power failure, so instead, mine just loses power and stays exactly where it was when power is cut.
      I am using a 24v PSU on a Core X/Y printer and the Duet 2 wifi board is writing the resurrect.g file on power cut.
      I'm using the exact same config.g. line listed on the above link:
      M911 S21.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
      Is there anything I can do to make it lift the nozzle a few mm on power cut?
        If it's a heavy bed there might not be enough juice left in the PSU to move the motor. You might be able to add some capacitors to boost the residual capacity slightly.
        This thread might have the info you'd need to know.
        https://forum.duet3d.com/topic/19468/resume-from-power-outage-really-only-with-24v?
