    Cnc pendant + paneldue
    CNC
    cnc pendant paneldue duet wifi
    939
    • Krohm Koalaundefined
      Krohm Koala
      Hi, i want to make a cnc pendant for duet 2 wifi, removable, and keep the paneldue always connected, so, is it possible to keep the paneldue on it's own connector and connect the pendant on the Conn_SD ? Or it'll have conflicts (only one will be used at a time) ?
      JoeSmaleundefined 1 Reply Last reply Reply Quote 0
      • SupraGuyundefined
        SupraGuy
        I'm looking at some of the same things. In my case though, the PanelDue is the more likely to be disconnected, as it's useful on my 3D printer, whereas a pendant probably would not be.
        The PanelDue is basically a serial communication device, connecting to a 4 pin serial port at (by default) 57,600 BPS. There are a few other communication channels open to the Duet, the Conn_SD is one of them. The PanelDue generates gcode commands which it transmits to the Duet over the serial channel. A pendant would probably just have controls at more of a hardware level, so I wouldn't think that they should conflict so much. Of course it depends on how smart you make your pendant to be, and how you want it to interface to the Duet firmware.
        Lead screw driven printer, powered by Duet 2 Wifi
        MPCNC powered by Duet 2 Wifi
        CoreXY printer driven by Duet 3 6HC
        LowRider CNC powered by Duet 2 Wifi
          dc42 administrators @SupraGuy
          Duet 2 boards have only one free serial port. [Duet 3 boards have two, but currently only the first one can support a PanelDue.] To connect both a pendant and a PanelDue to the same serial port, the TxD line from PanelDue is routed through the pendant, which receives the commands from PanelDue and forwards them to the Duet. The pendant doesn't receive any data from the Duet, so the PanelDue RxD line is connected directly to the Duet.
          This connection scheme means that if you disconnect the PanelDue, the pendant will still work. However, if you disconnect the pendant then in order for PanelDue to work, you will need to bridge the pendant receive and transmit data signals.
          Krohm Koalaundefined 1 Reply Last reply Reply Quote 0
            Krohm Koala @dc42
            @dc42 hum... It'll be problematic. I'll consider a switch to bridge. Thanks for the answer.
            • JoeSmaleundefined
              JoeSmale @Krohm Koala
              @krohm-koala - I've never tried it but I can't see why you couldn't use the Pendant we designed at the same time as a Paneldue. https://www.ebay.co.uk/itm/333891754636
              Let me know if you think this will suit your needs. You'll need to be running a windows PC for the software.
              Krohm Koalaundefined 1 Reply Last reply Reply Quote 1
                Krohm Koala @JoeSmale
                @joesmale we don't want to use your pendant, we've seen it many times, it's nice but expensive for what we want to do, and also, we love open source ^^
                • JoeSmaleundefined
                  @krohm-koala - Sorry, I was only trying to help mate. Took us months to develop so personally I see it as a lot cheaper then making one.
                    @joesmale it was not offensive and I thank you for your wanted to help ^^ sorry if you have read it like that, I know that developing a product is expensive and time consuming, I totally understand that you want to make money with it ^^ your pendant is just far out of our budget as it is around 150-160€ for us with shipping ^^
                    • JoeSmaleundefined
                      @krohm-koala - Thank you for your reply. I was just trying to point out that you should value your own time, even a day developing your own and you are basically valuing your time at very little per hour after material costs. Thats why we made them available for others. Take care.
