Duet 3 mini 5+ Wifi v1.0 SD card not accessible
A while back, I bought a Duet 3 mini 5+ Wifi v1.0 SD, but only just finished a build with it.
Unfortunately, it has the same behavior as my v0.5 Ethernet one did with SD cards. M21 results in an Error: M21: Cannot initialize SD card 0: Card is unusable.
I repeated all the steps that I did with the last board.
- Connected with YAT, sent M21 - this doesn't go through. I get the above error.
- Exchange the SD card (just in case, since the data on the card was just fine)
- Reformat the original card
- Try the card in the replaced v1.0 ethernet - it worked
To quote a classic "He's dead, Jim".
In this thread, @dc42 - you mentioned that a noclean flux pen and hot air equipment can get this fixed easy. Is this something you could describe? Or should I not even attempt it and just try E3D again for a replacement if you would authorize it?
@pkos, I'm sorry your Duet appears to be faulty and I approve a warranty replacement. Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
