    Problems with Smart IR Probe or Faulty
    Accessories and Add-ons
    318
    • TomasLundefined
      TomasL
      My 5 month old Smart IR probe seems to be malfunctioning.
      When I switch on the printer it first give one flash then after a while 4 flashes
      In Duet2, readings are always 0, regardles what I do.
      When I looked on the IR-LEDs with my phone-camera I can only see one LED on, the other one seems to be off.
      Any suggestions on how to proceed, I would imagine that it is faulty, since there is not muych one can do.
        Can you post a photo of the board?
        How is it wired?
        Firmware version?
        Config.g?
        What happens when you try to use it?
        • TomasLundefined
          TomasL
          Absolutly nothing happens, the red led is suppoosed to light up when it is triggered, that does not happen.
          Photo, well it is the smart ir-probe that duet3d sells
          https://www.duet3d.com/DuetAddons/IRProbe
          Neither firmware nor config.g should affect the board and its operation.
          ANd as I wrote earlier, it seems that one of the IR-LEDs is not working.
          Obviously the board needs to be replaced, but it sems that I shoulkd post here first, in order to get the warranty.
          • TomasLundefined
            TomasL
            Still waiting for an answer from Duet-people, so I can have the probe replaced.
              The reason for the photo is to try and spot a failed component or damage to aid in the trouble shooting.
              When and where was it purchased?
              • TomasLundefined
                TomasL
                Ok, well, it was purchased from RepRapMe here in Sweden, but they cannot do anything until I get an RMA from DUET.
                Ill see if I can sort out a photo
                  Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                  • TomasLundefined
                    TomasL
                    Ok, will do.
