    Panel Due not started when plugged into duet
    Firmware installation
    639
    • Festivejellyundefined
      Festivejelly
      I updated the Panel Due firmware (v3) to the latest and when its connected to my PC the panel starts fine and all the controls work. When I plug it into my duet it stays black when the duet starts.
      Am I missing a step here? The wiring is correct ive changed nothing, all I did was remove it to update the firmware.
        So it was working before the update, but not now?
        What firmware version was the PanelDue before? What version is it now?
        What firmware version is the Duet?
        How are you connecting it to the Duet? 4-wire or ribbon cable?
        Which hardware version of paneldue is it?
        Which firmware bin file did you use specificall?
        Festivejellyundefined 1 Reply Last reply Reply Quote 0
          Festivejelly @Phaedrux
          @phaedrux Correct it was working before.
          It had version 1.23 I think on it?
          Its now 3.2.11
          Duet has version 3.2.2
          Im connecting via the 4 wire's just as I was before.
          The hardware version says its v3.0a on the back
          I used PanelDueFirmware-v3-7.0.zip from here https://github.com/Duet3D/PanelDueFirmware/releases
          It works fine when powered from USB all touch controls work etc. But when I unplug the USB and install the 4 wire connector and turn on the printer I get nothing.
          I double checked and I have M575 P1 S1 B57600
          In my config.g
          I made very sure when I was removing the panel not to mess around with any connectors etc.
          But I just get nothing when the printer starts.
            Is it a 7i (as in integrated)? Or does it have the separate PCB connected to the display?
            Can you check the wiring harness to verify that you're still getting voltage at the paneldue end?
              @phaedrux It is a separate board. Theres a green board that plugs into a blue display. I've checked with my multimeter on the board when not attached the the panel and its getting 5v.
              When I attach it to the panel and test the pins it goes down to 1v.
              If I take it off and plug into USB it turns on fine.
              This leads my to think a config is wrong somewhere, like whatever is telling it to turn on... isnt.
                Can you post the results of M122 and your full config.g?
                  @phaedrux Sure, thanks for the help so far btw.
                  M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later + DueX5
                  Board ID: 08DGM-917DA-G4MSD-6J9DD-3S86K-18U3A
                  Used output buffers: 3 of 24 (15 max)
                  Static ram: 23460
                  Dynamic ram: 75864 of which 24 recycled
                  Never used RAM 12732, free system stack 193 words
                  Tasks: NETWORK(blocked,182) HEAT(blocked,310) DUEX(blocked,31) MAIN(running,449) IDLE(ready,20)
                  Owned mutexes: WiFi(NETWORK)
                  Last reset 00:00:17 ago, cause: power up
                  Last software reset at 2021-05-17 20:05, reason: User, GCodes spinning, available RAM 12280, slot 1
                  Error status: 0x00
                  Aux0 errors 87,87,87
                  MCU temperature: min 26.2, current 30.0, max 30.1
                  Supply voltage: min 24.2, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: position 0, standstill, SG min/max not available
                  Driver 1: position 0, standstill, SG min/max not available
                  Driver 2: position 0, standstill, SG min/max not available
                  Driver 5: position 0, standstill, SG min/max not available
                  Driver 6: position 0, standstill, SG min/max not available
                  Driver 7: position 0, standstill, SG min/max not available
                  Driver 8: position 0, standstill, SG min/max not available
                  Driver 9: position 0, standstill, SG min/max not available
                  Driver 10: position 0
                  Driver 11: position 0
                  Date/time: 2021-05-18 17:01:38
                  Cache data hit count 20676095
                  Slowest loop: 140.15ms; fastest: 0.22ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 30.3ms, write time 0.0ms, max retries 0
                  === MainDDARing ===
                  === AuxDDARing ===
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is assembling a command in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 149.28ms; fastest: 0.00ms
                  HTTP sessions: 1 of 8
                  - WiFi -
                  Network state is active
                  WiFi firmware version 1.25
                  WiFi MAC address ec:fa:bc:25:33:91
                  WiFi Vcc 3.37, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 23352
                  WiFi IP address 192.168.1.112
                  WiFi signal strength -57dBm, mode 802.11n, reconnections 0, sleep mode modem
                  Clock register 00002002
                  === DueX ===
                  Read count 1, 3.39 reads/min
                  Config:
                  ; Configuration file for Duet WiFi / Ethernet running RRF3 on E3D Tool Changer
                  M111 S0 						; Debugging off
                  G21 							; Work in millimetres
                  G90 							; Send absolute coordinates...
                  M83 							; ...but relative extruder moves
                  M555 P2 						; Set firmware compatibility to look like Marlin
                  M667 S1 						; Select CoreXY mode
                  M575 P1 S1 B57600 ;enable duet display
                  M550 P"ToolChanger" 			; Set machine name
                  M552 S1							; Enable Networking
                  M586 P0 S1 						; Enable HTTP
                  M586 P1 S0 						; Disable FTP
                  M586 P2 S0 						; Disable Telnet
                  ; Drive direction
                  M569 P0 S0 						; Drive 0 X
                  M569 P1 S0 						; Drive 1 Y
                  M569 P2 S1 						; Drive 2 Z
                  M569 P3 S1 						; Drive 3 E0
                  M569 P4 S1 						; Drive 4 E1
                  M569 P5 S1 						; Drive 5 E2
                  M569 P6 S1 						; Drive 6 E3
                  M569 P7 S0 						; Drive 7 COUPLER
                  M569 P8 S0 						; Drive 8 UNUSED
                  M569 P9 S0 						; Drive 9 UNUSED
                  M584 X0 Y1 Z2 C7 E3:4:5:6 								; Apply custom drive mapping
                  M208 X-35:328.5 Y-49:243 Z0:300 C-45:360	 				; Set axis maxima & minima
                  M92 X100 Y100 Z1600 C91.022 E394:394:394:394				; Set steps per mm assuming x16 microstepping
                  M350 E16:16:16:16 I1 									; Configure microstepping with interpolation
                  M350 C16 I10											; Configure microstepping without interpolation
                  M350 X16 Y16 Z16 I1										; Configure microstepping with interpolation
                  M566 X400 Y400 Z8 C2 E2:2:2:2							; Set maximum instantaneous speed changes (mm/min)
                  M203 X35000 Y35000 Z1200 C5000 E5000:5000:5000:5000	; Set maximum speeds (mm/min)
                  M201 X6000 Y6000 Z400 C500 E2500:2500:2500:2500			; Set accelerations (mm/s^2)
                  M906 X1800 Y1800 Z1330 I30   						; Idle motion motors to 30%
                  M906 E1000:1000:1000:1000 C500 I10     						; Idle extruder motors to 10%
                  M574 X1 Y1 S3 					; Set X / Y endstop stall detection
                  M574 C0 Z0  						; No C Z endstop
                  ; Z probe
                  M558 P8 C"zstop" H8 F360 I0 T20000 	; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
                  G31 P200 X0 Y0 Z0	 				; Set Z probe trigger value, offset and trigger height
                  M557 X10:290 Y20:180 S40 			; Define mesh grid
                  ;Stall Detection
                  M915 X Y S3 F0 H400 R4700				; X / Y Axes
                  M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4138 C0 		; Set thermistor
                  M950 H0 C"bedheat" T0											; Bed heater
                  M143 H0 S225 													; Set temperature limit for heater 0 to 225C
                  M140 H0															; Bed heater is heater 0
                  M308 S1 P"e0temp" Y"thermistor" A"T0" T100000 B4725 C7.06e-8 	; Set thermistor
                  M950 H1 C"e0heat" T1											; Extruder 0 heater
                  M143 H1 S305 													; Set temperature limit for heater 1 to 300C
                  M308 S2 P"e1temp" Y"thermistor" A"T1" T100000 B4725 C7.06e-8 	; Set thermistor
                  M950 H2 C"e1heat" T2											; Extruder 0 heater
                  M143 H2 S305 													; Set temperature limit for heater 2 to 300C
                  M308 S3 P"e2temp" Y"thermistor" A"T2" T100000 B4725 C7.06e-8 	; Set thermistor
                  M950 H3 C"duex.e2heat" T3										; Extruder 0 heater
                  M143 H3 S305 													; Set temperature limit for heater 3 to 300C
                  M308 S4 P"e3temp" Y"thermistor" A"T3" T100000 B4725 C7.06e-8 	; Set thermistor
                  M950 H4 C"duex.e3heat" T4										; Extruder 0 heater
                  M143 H4 S305 													; Set temperature limit for heater 4 to 300C
                  M563 P0 S"T0" D0 H1 F2 					; Define tool 0
                  G10 P0 X0 Y0 Z0 						; Reset tool 0 axis offsets
                  G10 P0 R0 S0 							; Reset initial tool 0 active and standby temperatures to 0C
                  M563 P1 S"T1" D1 H2 F4 					; Define tool 1
                  G10 P1 X0 Y0 Z0 						; Reset tool 1 axis offsets
                  G10 P1 R0 S0 							; Reset initial tool 1 active and standby temperatures to 0C
                  M563 P2 S"T2" D2 H3 F6 					; Define tool 2
                  G10 P2 X0 Y0 Z0 						; Reset tool 2 axis offsets
                  G10 P2 R0 S0 							; Reset initial tool 2 active and standby temperatures to 0C
                  M563 P3 S"T3" D3 H4 F8 					; Define tool 3
                  G10 P3 X0 Y0 Z0 						; Reset tool 3 axis offsets
                  G10 P3 R0 S0 							; Reset initial tool 3 active and standby temperatures to 0C
                  M950 F1 C"fan1"
                  M950 F2 C"fan2"
                  M950 F3 C"duex.fan3"
                  M950 F4 C"duex.fan4"
                  M950 F5 C"duex.fan5"
                  M950 F6 C"duex.fan6"
                  M950 F7 C"duex.fan7"
                  M950 F8 C"duex.fan8"
                  M106 P1 S255 H1 T70				; T0 HE
                  M106 P2 S0						; T0 PCF
                  M106 P3 S255 H2 T70 			; T1 HE
                  M106 P4 S0						; T1 PCF
                  M106 P5 S255 H3 T70 			; T2 HE
                  M106 P6 S0 						; T2 PCF
                  M106 P7 S255 H4 T70				; T3 HE
                  M106 P8 S0						; T3 PCF
                  M593 F42.2						; cancel ringing at 42.2Hz (https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/)
                  ;M376 H15						; bed compensation taper
                  ;tool offsets
                  ; !ESTIMATED! offsets for:
                  ; V6-tool: X-9 Y39 Z-5
                  ; Volcano-tool: X-9 Y39 Z-13.5
                  ; Hemera-tool: X20 Y43.5 Z-6
                  G10 P0 X20 Y43.5 Z-4.4				; T0
                  G10 P1 X20 Y43.5 Z-5.35					; T1
                  G10 P2 X20 Y43.5 Z-5.1					; T2
                  G10 P3 X20 Y43.5 Z-5.01					; T3
                  ;M572 D0 S0.2 						; pressure advance T0
                  ;M572 D1 S0.2 						; pressure advance T1
                  ;M572 D2 S0.2 						; pressure advance T2
                  ;M572 D3 S0.2 						; pressure advance T3
                  M575 P1 S1 B57600				; Enable LCD
                  G29 S2							    ; disable mesh
                  T-1								      ; deselect tools
                  M501                    ; load config-override.g
                    Phaedrux Moderator @Festivejelly
                    @festivejelly said in Panel Due not started when plugged into duet:
                    Can you show exactly where you're testing? I suspect it comes down to the cable. Bad crimp possibly.
                      @phaedrux
                      Okay I actually got that wrong. Im testing the voltage on the back of the PanelDue v3 board at the 5v and Gnd pins and its reading 1.5v.
                      This seems a bit low to me. Its hard to test the pins on the cable directly as they are recessed. I've checked the cable going into the duet and it seems to be seated fine.
                      Could it be a crappy crimp would show a voltage drop?
                        dc42 administrators @Festivejelly
                        Even if the 5V wire was missing completely, you would still get a small voltage (maybe as much as 1.5V) by phantom power from the data wires. So yes, it may be caused by a bad crimp.
                          Festivejelly @dc42
                          Okie dokie ill try and inspect the crimps then and see what the dealio is. I dont have a crimping kit for those particular connectors but I assume Duponts would suffice?
                            In a pinch.
                              @phaedrux So I tested the cables and all read 0.3ohms... apart from the red one which read 3 ohms.. Im going to try to see if I can remove just that one and re crimp it. I guess it means the voltage drops too much to power the panel. I might has somehow yanked it loose when I was removing the panel doh.
                                Thanks for the update. Let us know if improving the cabling helps.
                                  Sorry for the late reply, been side tracked. So basically cutting the cable and re crimping the end that plugs into the panel solved the issue. I went with duponts as they are easier to remove. Issue resolved.
