Solved Bigtreetech Smart Filament Sensor Setup
After switching wires from SGV to SVG I thought it will run.
I added "M591 D1 P7 C4 L7 R50:200 E15 S0" to the config.
By testing it with some moving filament with "M591 D1" i didn't receive any data.
Changing "P7" to "P1" in the config gives me switching states of filament present yes/no.Does somebody has an idea why P7 didn't work as suspected?
Take a look at this thread?
https://forum.duet3d.com/topic/17107/how-to-setup-the-bigtreetech-smart-filament-sensor
What firmware version are you using?
I read it it over and over again but didn't find it.
Firmware is 2.03 -
Can you update your firmware to 2.05? Upload this zip file to the system tab in DWC. Don't extract it first, just upload it.
Can you show a photo of how you have it connected?
C4 would mean you have it connected to the E1stop, is that right?
C4 is correct.
Firmware is updated.
The new output to "M591 D1" is:
"Pulse-type filament monitor on endstop input 4, disabled, sensitivity 7.000mm/pulse, allowed movement 50% to 200%, check every 15.0mm, no calibration data" -
I don't know if it is helpfull.
M569 P2 S1 ; Z drive 2 goes forwards
M569 P5 S1 ; U drive 5 goes backwards COLORselector
M569 P7 S0 ; X drive 7 goes backwards
M569 P8 S0 ; Y drive 8 goes backwards
M569 P9 S0 ; E0 drive 9 goes backwards PREextruder
M569 P10 S1 ; E1 drive 10 goes backwards DIRECTdriveM350 X32 Y32 Z64 U32 E32:16 I1 ; Configure microstepping with interpolation
M92 X80.00 Y80.00 Z6400.00 U400 E187:1840 ; Set steps per mm
M566 X900.00 Y900.00 Z10.00 U150 E200:200 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z500.00 U1000 E500:500 ; Set maximum speeds (mm/min)
M201 X1500.00 Y1500.00 Z300.00 U1500 E500:500 ; Set accelerations (mm/s^2)
M906 X600.00 Y600.00 Z600.00 U400 E400:600 I25 ; Set motor currents (mA) and motor idle factor in per cent
M208 X0 Y0 Z0 U0 S1 ; Set axis minima
M208 X200 Y205 Z215 U70 S0 ; Set axis maxima; Endstops
M574 X0 Y0 Z0 U0 S0 ; Set active low endstops
;M591 D0 P7 C"e1_stop" S1 R80:120 L6.2 E18.6
;M591 D1 P1 C4 S1
M591 D1 P7 C4 L7 R50:200 E15 A1 S0 ; Filamentsensor Gcode__________________________________________________________________________; Z-Probe
M307 H3 A-1 C-1 D-1
M558 P9 H5 F100 T2000
G31 X15.5 Y-25.75 Z1.792 P25; Heaters
M143 H0 S90 ; Set maximum bed temperature to 90C
M143 S280 ; Set maximum heater temperature to 280C
M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
M301 H2 S1.00 P11 I0.375 D59 T0.4 W180 B30 ; Use PID on nozzle heater (may require further tuning)
M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for bed heater 0
M305 P2 T100000 B4138 R4700 ; Set thermistor + ADC parameters for hotend heater 2; Fans
M06 P1 S0 I0 F500 H2 T40 C"Partcooler" ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S0 I0 F500 C"Light" ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0:1 H2 S"White" ; Define tool 0
M568 P0 S1 ; Enable mixing for tool 0
M567 P0 E0.50:0.50 ; Set mixing ratios for tool 0M563 P1 D0:1 H2 S"Infill" ; Define tool 1
G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
M568 P1 S1 ; Enable mixing for tool 1
M567 P1 E0.50:0.50 ; Set mixing ratios for tool 1M563 P2 D0:1 H2 S"TPU" ; Define tool 2
G10 P2 X0 Y0 Z0 ; Set tool 2 axis offsets
M568 P2 S1 ; Enable mixing for tool 2
M567 P2 E0.50:0.50 ; Set mixing ratios for tool 2M563 P3 D0:1 H2 S"Magenta" ; Define tool 3
G10 P3 X0 Y0 Z0 ; Set tool 3 axis offsets
M568 P3 S1 ; Enable mixing for tool 3
M567 P3 E0.50:0.50 ; Set mixing ratios for tool 3M563 P4 D0:1 H2 S"Cyan" ; Define tool 4
G10 P4 X0 Y0 Z0 ; Set tool 4 axis offsets
M568 P4 S1 ; Enable mixing for tool 4
M567 P4 E0.50:0.50 ; Set mixing ratios for tool 4M563 P5 D0:1 H2 S"Yellow" ; Define tool 5
G10 P5 X0 Y0 Z0 ; Set tool 5 axis offsets
M568 P5 S1 ; Enable mixing for tool 5
M567 P5 E0.50:0.50 ; Set mixing ratios for tool 5M563 P6 D0:1 H2 S"Black" ; Define tool 6
G10 P6 X0 Y0 Z0 ; Set tool 6 axis offsets
M568 P6 S1 ; Enable mixing for tool 6
M567 P6 E0.50:0.50 ; Set mixing ratios for tool 6M563 P7 D0:1 H2 S"DIRECT ONLY" ; Define tool 7
G10 P7 X0 Y0 Z0 ; Set tool 7 axis offsets
M568 P7 S1 ; Enable mixing for tool 7
M567 P7 E0.00:0.50 ; Set mixing ratios for tool 7 -
@phaedrux said in Bigtreetech Smart Filament Sensor Setup:
no ideas left?
I guess I was hoping the wires would have different colours so I could tell which wire is going to which pin.
Maybe you can guide me?
@phaedrux there is a dot, a thin line and a filled rectangle on it to guide.
Thanks, that helps. So it looks like it's wired correctly based on that previous thread.
Can you try:
M591 D1 P7 C4 L0.5 R90:110 E3 S0
If that still doesn't work I might consider updating to RRF3. RRF2 is starting to get stale. Even 2.05 is over a year old now.
hi @phaedrux
Also setting up my printer with firmware 3.2.2 delivers "Pulse-type filament monitor on pin e1stop, disabled, sensitivity 0.500mm/pulse, allowed movement 90% to 110%, check every 3.0mm, no calibration data"
Ok, and with S1 to enable it?
And start a print to get it calibrated?
https://duet3d.dozuki.com/Wiki/Duet3dFilamentMonitor_RotatingMagnetVersion#Section_Calibration
@phaedrux THANK YOU
it works. finetuning is needed, but not the problem.
