    Error M280
    Firmware installation
    1
    • hbrownellundefined
      hbrownell
      So, I just did the update to 3.2 and my BL Touch is not connecting apparently.
      Error: M280: Invalid servo index 0 in M280 command
      From config.g
      G31 P25 X29 Y-6.5 Z1.2 ; set Z probe trigger value, offset and trigger height
      M557 X20:180 Y20:180 S80 ; define mesh grid
      ; deployprobe.g
      ; called to deploy a physical Z probe
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun May 16 2021 20:01:35 GMT-0500 (Central Daylight Time)
      M280 P0 S10 ; deploy BLTouch
      I followed this image to make my connections.
      hbrownellundefined 1 Reply Last reply Reply Quote 0
        hbrownell @hbrownell
        @hbrownell Never mind. I just needed to update the firmware to 3.22.. it was still on 2.05.
