    Solved Error M308 Response TimeOut....Thermistors on EXP 3HC
    Firmware installation
    122
    • 2K3M
      2K3M last edited by
      I have a question hoping someone can point me in the right direction about.
      Using a 6HC Mainboard and a 3HC EXP board.
      I have a heated chamber and wanting to setup 2 thermistors that probe the air in different parts of the chamber.
      I have two thermistors plugged into the exp 3hc into temp0 and temp1. I have the exp 3HC CAN address set to 1. I have my thermistors addressed as such:
      M308 S3 P"0.temp0" Y"thermistor" A"Keenovo_Temp" T100000 B4138 H0 L0 ;Keenovo Pad thermistor - connected to Mainboard temp0
      M308 S0 P"0.temp1" Y"thermistor" A"Bed_Temp" T100000 B4138 H0 L0 ;Bed Thermistor - Connected to Mainboard temp1
      M308 S1 P"0.temp2" Y"thermistor" A"e0_heat" T500000 B4725 C7.06e-8 H0 L0 ;duet3 e3d thermistor - connected to Mainboard e0_heat
      M308 S2 P"0.temp3" Y"thermistor" A"Chamber_Heater_Temp" T100000 B4240 H0 L0 ;Chamber Thermistor - connected to Mainboard temp3
      M308 S4 P"1.temp0" Y"thermistor" A"Lower_Chamber_Temp" T100000 B4138 H0 L0 ;Chamber Thermistor - connected to EXP temp0
      M308 S5 P"1.temp1" Y"thermistor" A"Upper_Chamber_Heater_Temp" T100000 B4138 H0 L0 ;Chamber Thermistor - connected to EXP temp1
      im getting an error on CAN addr 1
      Error: M308: Response Timeout: CAN Addr 1, req type 6031, RID=0
      Error: M308: Response Timeout: CAN Addr 1, req type 6031, RID=1
      Assuming i have this addressed wrong...,but i did some google searches on the error but not much turned up....any input or can someone point me in the right direction to find a list of error codes?
      2K3M 1 Reply Last reply Reply Quote 0
      • 2K3M
        2K3M @2K3M last edited by 2K3M
        When i run M98 P"config.g" i get the following
        Warning: Discarded msg src=1 typ=4510 RID=4095 exp 5
        Warning: Discarded msg src=1 typ=4510 RID=4095 exp 6
        Error: M308: Response timeout: CAN addr 1, req type 6031, RID=5
        Error: M308: Response timeout: CAN addr 1, req type 6031, RID=6
          Can you send M122 and M122 B1 and provide the results?
          2K3M 5 Replies Last reply Reply Quote 0
          • 2K3M
            2K3M @Phaedrux last edited by
            This post is deleted!
            • 2K3M
              @phaedrux
              M122 B1
              Diagnostics for board 1:
              Board EXP3HC firmware 3.1.0 (2020-05-15b1)
              Never used RAM 163.6Kb, max stack 304b
              HEAT 1196 CanAsync 1452 CanRecv 1420 TMC 156 AIN 524 MAIN 2184
              Last reset 00:01:52 ago, cause: software
              Driver 0: standstill, reads 17726, writes 11 timeouts 0, SG min/max 0/0
              Driver 1: standstill, reads 17728, writes 11 timeouts 0, SG min/max 0/0
              Driver 2: standstill, reads 17730, writes 11 timeouts 0, SG min/max 0/0
              Moves scheduled 0, completed 0, hiccups 0
              VIN: 24.3V, V12: 12.3V
              MCU temperature: min 39.7C, current 39.9C, max 39.9C
              Ticks since heat task active 96, ADC conversions started 112340, completed 112339, timed out 0
              Last sensors broadcast 00000000 found 0 99 ticks ago
              Free CAN buffers: 36
              NVM user row de9a9239 aeecffb1 ffffffff ffffffff
              • 2K3M
                @phaedrux
                M122
                RepRapFirmware for Duet 3 MB6HC version 3.2.2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                Board ID: 08DJM-956L2-G43S8-6J1F4-3SJ6M-TA0YG
                Used output buffers: 1 of 40 (12 max)
                Static ram: 149788
                Dynamic ram: 63064 of which 36 recycled
                Never used RAM 145944, free system stack 200 words
                Tasks: Linux(ready,109) HEAT(blocked,219) CanReceiv(blocked,848) CanSender(blocked,371) CanClock(blocked,354) TMC(blocked,53) MAIN(running,1080) IDLE(ready,19)
                Owned mutexes: HTTP(MAIN)
                Last reset 00:01:28 ago, cause: software
                Last software reset at 2021-05-19 05:01, reason: User, none spinning, available RAM 145944, slot 1
                Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
                Error status: 0x00
                Aux0 errors 0,0,0
                Aux1 errors 0,0,0
                MCU temperature: min 35.2, current 35.3, max 36.3
                Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0
                Driver 0: position 0, standstill, reads 58963, writes 0 timeouts 0, SG min/max not available
                Driver 1: position 0, standstill, reads 58963, writes 0 timeouts 0, SG min/max not available
                Driver 2: position 0, standstill, reads 58963, writes 0 timeouts 0, SG min/max not available
                Driver 3: position 0, standstill, reads 58962, writes 0 timeouts 0, SG min/max not available
                Driver 4: position 0, standstill, reads 58962, writes 0 timeouts 0, SG min/max not available
                Driver 5: position 0, standstill, reads 58962, writes 0 timeouts 0, SG min/max not available
                Date/time: 2021-05-19 05:02:57
                Slowest loop: 130.01ms; fastest: 0.04ms
                === Storage ===
                Free file entries: 10
                === MainDDARing ===
                === AuxDDARing ===
                Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1
                Segments left: 0
                Movement lock held by null
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                SBC is idle in state(s) 0
                Daemon is idle in state(s) 0
                Aux2 is idle in state(s) 0
                Code queue is empty.
                === CAN ===
                Messages queued 324, send timeouts 0, received 15, lost 0, longest wait 120ms for reply type 6024, free buffers 48
                === SBC interface ===
                State: 4, failed transfers: 0
                Last transfer: 1ms ago
                RX/TX seq numbers: 2955/2955
                SPI underruns 0, overruns 0
                Number of disconnects: 0, IAP RAM available 0x2c884
                Buffer RX/TX: 0/0-0
                === Duet Control Server ===
                Duet Control Server v3.2.2
                Code buffer space: 4096
                Configured SPI speed: 8000000 Hz
                Full transfers per second: 35.28
                Maximum length of RX/TX data transfers: 3108/832
                • 2K3M
                  @phaedrux
                  M115 B1
                  M308 S4
                  Error: M308: Sensor 4 does not exist
                  M308 S5
                  Error: M308: Sensor 5 does not exist
                  config.g
                  • 2K3M
                    @phaedrux
                    To be clear these sensors/thermistors are not assigned to a particular heater. They are just sensors im using to see how even my chamber heats. The sensors are plugged into the 3HC Expansion board...at this time no other heaters or sensors are connected to the expansion board....just these 2 thermistors. Not sure if there are FW limitations on the 3HC EXP where a temp sensor must be assigned to a Heater or a Tool on the same board?
                      dc42 administrators @2K3M last edited by
                      @2k3m you are running incompatible firmware versions on the main board and expansion board. Upgrade the expansion board firmware to 3.2.2.
                      2K3M 3 Replies Last reply Reply Quote 0
                      • 2K3M
                        2K3M @dc42 last edited by
                        Thank you I will do so and report back!
                        • 2K3M
                          by chance can you link a good how to on this?
                          • 2K3M
                            Where is the firmware located? Im on Github...
                            Is it under
                            Duet3D/Duet3Expansion? or Duet3D/RepRapFirmware?
                              @2k3m it's in the Releases section of RepRapFirmware. https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2.2
                              2K3M 2 Replies Last reply Reply Quote 0
                              • 2K3M
                                You are the best thank you very much!
                                • 2K3M
                                  That did the trick! The updating wasn't too bad either. Link listed below for how to for convenience of others. Again thank you very much for the help!
                                  https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware
