    Delta larger Print Size
    Config Tool
    • manjoel
      manjoel last edited by
      Hallo, I have an Kossel with an Z hight of 40 cm and an radius of of 18 cm. I wanted to swith from my old ramp to an Duet3 to test little bit arround.
      But I can't use this sizes in the config Tool. I there an reason there for?
      Greeds
      Joel
        dc42 administrators @manjoel last edited by dc42
        @manjoel where is it preventing you from entering those values? Most likely, one of the other values you have entered is not compatible with those values.
        Barracuda72 1 Reply Last reply Reply Quote 0
        • Barracuda72
          Barracuda72 @dc42 last edited by
          @dc42 i wondered about that strange behavior too..got a 300mm diameter Delta...and if i wanted to fill in 150mm printable radius it wont accept it...reason is ( and thats just after i saw you post: in the tool the delta radius cant be smaller than the printable radius...so..if i want my 150mm printable radius i have first fill in at least 150mm delta radius
