    gray overlay blocking UI 3.4 RC2
    Beta Firmware
    327
    • resam
      resam last edited by Phaedrux
      I'm using Duet Web Control 3.2.2 in Chrome on macOS.
      If I open DWC from my bookmarks in a new tab but do not view it right away (meaning: opening the tab in the background while keeping focus on my current tab), there is a gray UI overlay that blocks the entire screen. I think this is a left-over from the "Connecting..." UI element that does not get cleared properly. The full UI is still visible and updates properly, but I can't click any of the buttons, and it has this 50% gray over everything.
      I tried an incognito window (to rule out any Chrome extensions), but it still happens.
      @chrishamm is this something you can track down easily? My DOM looks like this in the "broken" state:
      If I remove the div.v-overlay it clears it and I can use the UI.
      A simple page reload while "looking at this tab" also works - but is annoying.
      chrishamm 1 Reply Last reply Reply Quote 1
      • chrishamm
        chrishamm administrators @resam last edited by chrishamm
        @resam It's a bug in the VuetifyJS framework used by DWC but hopefully resolved in 3.3-RC3. Please feel free to try the newer version and check if the problem persists.
        Duet software engineer
        resam 1 Reply Last reply Reply Quote 0
        • resam
          resam @chrishamm last edited by
          @chrishamm unfortunately I still have this problem with the final 3.3.0 DWC installed via the apt repos.
          • resam
            resam @resam last edited by
            @chrishamm this is still an issue with v3.4-rc2!
            chrishamm 1 Reply Last reply Reply Quote 0
            • Moved from Duet Web Control by  Phaedrux Phaedrux
            • chrishamm
              @resam how can you reproduce it? I haven't seen it for ages.
              • resam
                @chrishamm a video says more than a 1000 words.
                Chrome on macOS: dwc-gray-overlay.mp4
                • oliof
                  oliof last edited by
                  I can confirm that I see this on and off, but I got so used to just reloading that I forgot about it /-:
                  <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
                  • Fred-Y
                    Fred-Y last edited by
                    I have also this problem but it's not new for me, I'm pretty sure I had this issue for a long time, well before the betas of 3.4.
                    It happens on my Duet 2, Duet 3 6HC and Mini regardless if they are wifi or wired.
                    Last time I checked, it was not related to the browser (Chrome, Firefox or Edge) - as nobody reported it, I assumed it might be related to my meshed network.
                    As Oliof said "I got so used to just reloading that I forgot about it"
                    • MintyTrebor
                      MintyTrebor last edited by MintyTrebor
                      I can confirm this behaviour on all 3 of my boards (2 Gloomy, 1 Duet). Tested with all internal and external plugins disabled just to be sure.
                      It's repeatable by hitting refresh on the tab and immediately switching tabs and waiting a couple of seconds, then tabbing back to a grey screen. I should also note that if the page is even partially rendered before tabbing off, the issue does not manifest.
                      I can not replicate this on firefox - only chromium based browsers (running on windows).
                      Notionally it seems to be influenced by the blue "connecting" dialog - if you go back to the duet tab before it closes the "connecting" dialog, the problem does not seem to manifest - but this could just be a red herring.
                      NodeDSF - Native Node-Red integration with Duet boards.
                      BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
                      ReleaseMgr - Duet update info inside DWC.
                      Repo
