    Reusing e1stop for a DHT22
    • paralepsisundefined
      paralepsis
      Hi all, I've hooked up a DHT22 using the expansion pins as follows:
      ; DHT22 (pin 1 +V, pin 2 GND, pin 4 (E2 Stop) Data)
      M308 S2 P"exp.e2_stop" Y"dht22" A"AmbTemp[C]"
      M308 S3 P"S2.1" Y"dhthumidity" A"AmbHumid[%]"
      This works fine, but I'm not using the E1 stop and thought I would instead reuse that as it has a keyed connector and so I'm less likely to goof something. I tried this:
      M308 S2 P"e1stop" Y"dht22" A"AmbTemp[C]"
      That doesn't work :). I'm sure I've done something silly, like forgetting to free the e1stop pin or something, but I am not finding the answer.
      Help? Thanks!
      Rob
      Railcore II 300XL w/ Duet 3 & RRF 3.5rc4, Makerbot R2X w/ Duet 2 WiFi & RRF 3.4
        dc42 administrators @paralepsis
        @paralepsis you haven't done anything silly, it's because e2stop e1stop has an input protection circuit, which prevents it being used as an output.
        paralepsisundefined 1 Reply Last reply Reply Quote 0
          paralepsis @dc42
          @dc42 Ah, thanks! Ok. I assume e0stop is the same, so I need to just use the e2stop approach?
            @paralepsis said in Reusing e1stop for a DHT22:
            Correct; or you can use one of the spi.cs signals on the SPI daughter board connector.
              paralepsis @dc42
              @dc42 Got it, thanks again!
