    SOLVED Home all axis at once
    Using Duet Controllers
    94
    • Saktziki
      Saktziki last edited by Saktziki
      Hi guys!
      I was wondering if there's a good way to home the XYZ axis all at once? Right now I homeall.g I home one axis at a time but because the printer is quite large it takes quite a long time.
      Thanks in advanced!
      chrishamm dc42 2 Replies Last reply Reply Quote 0
      • chrishamm
        chrishamm administrators @Saktziki last edited by
        @saktziki If you have independent endstop switches for every axis, that's certainly possible. You'd have to build your own G1 H1 code and move the axes to the endstops in one go (specify all the axes minima/maxima in the same command/line).
        Duet software engineer
        Saktziki 1 Reply Last reply Reply Quote 1
        • Saktziki
          Saktziki @chrishamm last edited by
          @chrishamm Okey so then I'll put in a separate G1 H1 command and not call each home script individually??
          Dougal1957 1 Reply Last reply Reply Quote 0
          • Dougal1957
            Dougal1957 @Saktziki last edited by
            @saktziki below is my homing script which homes all axis at the same time however be aware that this is for a delta so all are home to max but it may give you a clue.
            ; homedelta.g
            ; generated by RepRapFirmware Configuration Tool on Fri Jul 07 2017 14:49:07 GMT+0100 (BST)
            ; Use relative positioning
            G91
            ; Move all towers to the high end stopping at the endstops (first pass)
            ;*** Slow homing has been configured. Change F600 to F6000 below when your configuration is working
            G1 X585 Y585 Z585 F6000 H1
            ; Go down a few mm
            G1 X-5 Y-5 Z-5 F6000 H2
            ; Move all towers up once more (second pass)
            G1 X10 Y10 Z10 F360 H1
            ; Move down a few mm so that the nozzle can be centred
            G1 Z-5 F6000
            ; Switch back to absolute positioning and go to the centre
            G90
            G1 X0 Y0 F6000
            HTH
            Doug
            • Saktziki
              Awesome that works! But now I encountered a different problem. I back away from the endstops and the approach them slowly again but they don't stop.
              This is my code:
              ; Clear any bed transforms
              M561
              ; Clear babystepping
              M290 R0 S0
              ; Set to Relative Positioning
              G91
              ; Move Z down so we don't drag it on the bed
              G1 H1 F300 Z1
              ; Set to Absolute Positioning
              G90
              ; Move if not stopped by endstop first
              G1 H1 F1200 X700 Y475 Z900
              M400
              ; Back off endstop slowly
              G1 H0 F240 X-5 Y-5 Z-10
              M400
              ; Move to endstop again, slowly
              G1 H1 F120 X15 Y15 Z20
              ; Wait
              M400
              ; Set position
              G92 X645.00 Y445.00 Z576.6
              ; Wait 500 ms
              G4 P500
              ;; Move from endstop by 1mm
              G1 F720 X-1 Y-1 Z-5
              G90
                dc42 administrators @Saktziki last edited by dc42
                @saktziki if it's a Cartesian printer, see https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_The_homeall_g_file. This shows how to home X and Y together. If Z uses an endstop switch then you could also home Z at the same time.
                  @saktziki said in Home all axis at once:
                  Leave the printer in relative coordinate mode (G91) while homing and backing off.
                  Saktziki 1 Reply Last reply Reply Quote 0
                  • Saktziki
                    Saktziki @dc42 last edited by
                    @dc42 Thank you so much! I got it to work now 🙂
