    Your Duet rejected the HTTP request
    Using Duet Controllers
    • tkdirp
      tkdirp last edited by
      So, which file should I be chacking?
        Can you connect via USB terminal and send M122 and post the response here?
        Assuming you used this guide for mac os to get an IP address?
        https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s245
        Also send M22 to unmount, M21 to mount, and then M122 P104 S10 to test the sd card and post the responses.
          dc42 administrators @tkdirp last edited by
          @tkdirp which Duet is it?
          tkdirp 1 Reply Last reply Reply Quote 0
          • tkdirp
            tkdirp @dc42 last edited by
            @dc42 Duet Wifi 2
              @tkdirp that message suggests that RRF could not read file /www/index.html.gz. If that file appears OK but you are getting this message every time, then it probably means that the Duet is having trouble reading the SD card. So test this, connect via USB and and terminal emulator and run the following commands:
              • M122 (and look for the SD card statius in the response)
              • M503 (to see if config.g can be read)
              • M21 (to see if the SD card can be mounted)
              Veti 1 Reply Last reply Reply Quote 0
              • Veti
                Veti @dc42 last edited by
                what filesystem did you format the sd card with?
