Toolboard
@auré is the red status light on the tool board flashing slowly in sync with the one on the main board? Or flashing quickly? Or not flashing at all?
@auré in that case it doesn't have CAN sync. Verify this by sending M115 B121 to see whether you get a timeout message. If so, then most likely you have a bad CAN cable, or you have CAN_L and CAN_H swapped between the ends.
Note that you can also fail to get CAN sync if you have mismatched firmware versions on the main board and tool board; but if the only problem is mismatched firmware versions then most commands will still work including M115 B121.
For test I change the can l and can H and now the led red statut flash slowly and I send M115 B121 and I'm really sorry I was sure of me
@auré I'm glad you managed to fix it.
@auré See the M569 command.
@dc42 Thanks!
