    possible reasons for a "short to ground" error mid print?
    • r123undefined
      r123
      Mid-print started getting "Error Short to Ground reported by driver 0" (the X-axis stepper on my Railcore).
      Stopped the print, examined for a loose connector (that happened once before) annd errors kept rolling in every 5-10 secs. Out of ideas restarted the machine and now the errors stopped (as per console output below).
      Then tried homing the machine and errors came back in abundance (together with defective motion). Then took the lid off the machine (allowing everything to cool down after 70C chamber print) AND unplugged stepper connector, examined and replugged.
      Having restarted machines homes normally and all errors gone.
      What are the possible causes of the problem?
      • although the connector looks fine I know a loose connector can cause this problem;
      • could stepper overheating cause the problem? (they were running hot - though outside the build chamber they share some aluminium frame);
      • anything else?
      12/06/2021, 21:06:18 Connection established
      12/06/2021, 21:06:17 Connection interrupted, attempting to reconnect...
      HTTP request timed out
      12/06/2021, 21:06:05 Error: short-to-ground reported by driver(s) 0
      12/06/2021, 21:06:00 Error: short-to-ground reported by driver(s) 0
      12/06/2021, 21:05:56 Error: short-to-ground reported by driver(s) 0
      ps have these: https://www.moonsindustries.com/series/nema-23-high-precision-hybrid-stepper-motors-b020403
      r123undefined Vetiundefined 2 Replies Last reply Reply Quote 0
      • r123undefined
        r123 @r123
        @r123 well, it's happened twice more and I feel like an idiot just wiggling connectors. So have remapped the X from Drive 0 to Drive 4 and we'll see!
          dc42 administrators @r123
          @r123 which Duet are you using? If it's a Duet 3 or 3 Mini, and you are running the drivers in stealthChop mode, then the problem could be that you are running in stealthChop mode at speeds that are too high. This is documented in the Trinamic data sheets:
          davidewenundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti @r123
            @r123 said in possible reasons for a "short to ground" error mid print?:
            how hot. those steppers are Insulation Class B, 130℃.
            see https://www.engineeringtoolbox.com/nema-insulation-classes-d_734.html
            r123undefined 1 Reply Last reply Reply Quote 0
            • r123undefined
              r123 @Veti
              More than halfway through a 15hr prinit and printing like a dream (literally, I'm still half-asleep!). So far, no Driver 4 errors.
              @dc42 i'ts a Duet Wifi (and this iis the same print file as earlier failures) so that eliminates the trinamic thing.
              @veti thanks for the insight on stepper classes. The cases were probably not over about 60C so still have to do eggs in the pan.
              Remapping the driver didn't touch the connector at the stepper end so now inclined to think that issue is at PCB end of the wire. The PCB, the male or the female connector. Time will perhaps reveal.
              • davidewenundefined
                davidewen @dc42
                I have a Duet 3 mini 5+.
                I've been printing for days and suddenly in the middle of a big job I get Error: short-to-ground reported by driver(s)3.
                Extruder is a Bondtech DDX3
                I've swapped the driver for the original Ender 6 and same error.
                Any idea how to correct it?
                David
                  dc42 administrators @davidewen
                  @davidewen said in possible reasons for a "short to ground" error mid print?:
                  Please explain exactly what you mean by that.
