No wifi. Why?
  • Hi I'm new and trying to upgrade my FT-5 to run with a Diamond Hotend.
    I have updated firmware, made a setup in webconfigurator and put it in the sys directory on the SD-Card etc. but can't get any WiFi connection to work, what's wrong?
    m552 s0
    SENDING:M552 S0
    Setting hotend temperature to 1.000000 degrees Celsius.
    WiFi module started
    Error: Failed to initialise WiFi module, code -10
    [ERROR] Error: Failed to initialise WiFi module, code -10
    Sounds like you have upgraded the main firmware to 1.19 but not the WiFi firmware. The upgrade to 1.19 is different from most firmware upgrades. See https://duet3d.com/wiki/Upgrading_to_DuetWiFiFirmware_1.19.
    What you need to do now is create the /www folder (or delete all files and directories from the old one) and unzip the DuetWebControl files to it, also copy DuetWiFiServer-1.19.bin into /sys and rename it to DuetWiFiServer.bin. Then send M997 S1 from USB or PanelDue to install the new WiFi firmware.
Locked
