Firmware bundle 3.3.0 released
Apt update and apt upgrade upgraded the Duet 3 6HC main board firmware. It didn't upgrade DWC or the toolboards.
@beosdoc said in Firmware bundle 3.3.0 released:
What version were you on previously?
You can manually initiate the firmware flash by sending M997 B# where # is the can address of the tool board.
For DWC, I'm not sure the best way to update it if it has failed. Can you provide us the results of M122? Are you sure DSF updated at all?
@BeosDoc @phaedrux I doubt the DWC update actually failed. It's much more likely that your browser keeps a cached copy so try pressing Ctrl+Shift+R to force-reload the web interface. Then it should display v3.3.0.
We'll improve the way firmware updates are installed in v3.4 so that firmware updates for expansion board are installed as well.
@chrishamm - I've just swapped over to the latest DWC 3.3.0 from the CNC one. I prefer the smaller buttons in the dashboard - and lack of move to Go To Work XYZ Zero which would have caused a crash on my set-up. I have multiple tools which I can see now in CNC mode - I can see which mode I am in - as I will use a laser on my set up as well. I think the addition of the machine position and what work coordinate is active in the status bar would be good enough for me and most CNC users. Look forward to trying some of the new plugins too. Many thanks.
undefined Quadcells referenced this topic
undefined chrishamm unpinned this topic
