    Duet 3.3.0 upgrade kept back
    Firmware installation
    699
    • BlueDustundefined
      BlueDust
      I haven't seen this before during past updates and wanted to bring attention to it, and ask how to fix it before I tried anything.
      pi@duet3:~ $ sudo apt-get update
      Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
      Get:2 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
      Get:3 https://pkg.duet3d.com stable InRelease [2,563 B]
      Get:4 https://pkg.duet3d.com stable/armv7 armhf Packages [17.0 kB]
      Get:5 http://archive.raspberrypi.org/debian buster/main armhf Packages [375 kB]
      Fetched 442 kB in 2s (207 kB/s)
      Reading package lists... Done
      pi@duet3:~ $ sudo apt-get upgrade
      Building dependency tree
      Reading state information... Done
      Calculating upgrade... Done
      The following packages have been kept back:
        duetcontrolserver duetruntime duetsoftwareframework duettools duetwebcont
        duetwebserver libpulse-mainloop-glib0 libpulse0 libpulsedsp pulseaudio
        pulseaudio-module-bluetooth pulseaudio-utils reprapfirmware
      0 upgraded, 0 newly installed, 0 to remove and 13 not upgraded.
      pi@duet3:~ $
      Fun, that 3 letter word with "u" in the middle.
      • chrishammundefined
        chrishamm administrators
        @bluedust That can happen when apt pulls in new dependencies, but I didn't see it when I upgraded from v3.2.2 to v3.3.0. Try running sudo apt upgrade duetsoftwareframework and check if that resolves it.
        Duet software engineer
        BlueDustundefined 2 Replies Last reply Reply Quote 1
        • BlueDustundefined
          BlueDust @chrishamm
          @chrishamm
          Thanks!
          That did allow me to upgrade to 3.3, but still have some updates being held back.
          pi@duet3:~ $ sudo apt upgrade duetsoftwareframework
          The following NEW packages will be installed:
            apparmor duetpluginservice
          The following packages will be upgraded:
            duetwebcontrol duetwebserver reprapfirmware
          7 upgraded, 2 newly installed, 0 to remove and 6 not upgraded.
          Need to get 34.0 MB of archives.
          After this operation, 1,488 kB of additional disk space will be used.
          Do you want to continue? [Y/n]
          Get:1 https://pkg.duet3d.com stable/armv7 armhf duetsoftwareframework armhf                3.3.0 [2,046 B]
          Get:2 https://pkg.duet3d.com stable/armv7 armhf duettools armhf 3.3.0 [54.5                kB]
          Get:4 https://pkg.duet3d.com stable/armv7 armhf duetcontrolserver armhf 3.3               .0 [238 kB]
          Get:5 https://pkg.duet3d.com stable/armv7 armhf duetruntime armhf 3.3.0 [27               .2 MB]
          Get:3 http://mirror.pit.teraswitch.com/raspbian/raspbian buster/main armhf                apparmor armhf 2.13.2-10 [438 kB]
          Get:6 https://pkg.duet3d.com stable/armv7 armhf duetwebserver armhf 3.3.0 [               80.4 kB]
          Get:7 https://pkg.duet3d.com stable/armv7 armhf duetwebcontrol all 3.3.0 [4               ,816 kB]
          Get:8 https://pkg.duet3d.com stable/armv7 armhf reprapfirmware all 3.3.0-1                [1,034 kB]
          Get:9 https://pkg.duet3d.com stable/armv7 armhf duetpluginservice armhf 3.3               .0 [62.6 kB]
          Fetched 34.0 MB in 8s (4,357 kB/s)
          Reading changelogs... Done
          Preconfiguring packages ...
          (Reading database ... 79496 files and directories currently installed.)
          Preparing to unpack .../0-duetsoftwareframework_3.3.0_armhf.deb ...
          Unpacking duetsoftwareframework (3.3.0) over (3.2.2) ...
          To delete the "dsf" user run as root: userdel --force dsf
          Preparing to unpack .../1-duettools_3.3.0_armhf.deb ...
          Unpacking duettools (3.3.0) over (3.2.2) ...
          Preparing to unpack .../2-duetcontrolserver_3.3.0_armhf.deb ...
          Unpacking duetcontrolserver (3.3.0) over (3.2.2) ...
          To delete "gpio" group run as root: groupdel gpio
          Preparing to unpack .../3-duetruntime_3.3.0_armhf.deb ...
          Unpacking duetruntime (3.3.0) over (3.2.2) ...
          Preparing to unpack .../4-duetwebserver_3.3.0_armhf.deb ...
          Unpacking duetwebserver (3.3.0) over (3.2.2) ...
          Preparing to unpack .../5-duetwebcontrol_3.3.0_all.deb ...
          Unpacking duetwebcontrol (3.3.0) over (3.2.2) ...
          Preparing to unpack .../6-reprapfirmware_3.3.0-1_all.deb ...
          Unpacking reprapfirmware (3.3.0-1) over (3.2.2-1) ...
          Selecting previously unselected package duetpluginservice.
          Preparing to unpack .../7-duetpluginservice_3.3.0_armhf.deb ...
          Unpacking duetpluginservice (3.3.0) ...
          Selecting previously unselected package apparmor.
          Preparing to unpack .../8-apparmor_2.13.2-10_armhf.deb ...
          Unpacking apparmor (2.13.2-10) ...
          Setting up duetruntime (3.3.0) ...
          Setting up apparmor (2.13.2-10) ...
          Created symlink /etc/systemd/system/sysinit.target.wants/apparmor.service → /lib/systemd/system/apparmor.service.
          Setting up duettools (3.3.0) ...
          Setting up duetsoftwareframework (3.3.0) ...
          To modify config files consider adding yourself to the dsf groupd: # usermod -a -G dsf <username>
          Setting up duetwebcontrol (3.3.0) ...
          Setting up duetcontrolserver (3.3.0) ...
          Installing new version of config file /opt/dsf/conf/config.json ...
          Setting up duetwebserver (3.3.0) ...
          Setting up reprapfirmware (3.3.0-1) ...
          Sending update request to DCS... Done!
          Setting up duetpluginservice (3.3.0) ...
          Processing triggers for systemd (241-7~deb10u7+rpi1) ...
          Processing triggers for man-db (2.8.5-2) ...
          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
          Hit:3 https://pkg.duet3d.com stable InRelease
            libpulse-mainloop-glib0 libpulse0 libpulsedsp pulseaudio pulseaudio-module-bluetooth
            pulseaudio-utils
          0 upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
          duetsoftwareframework is already the newest version (3.3.0).
            pulseaudio-utils
          pi@duet3:~ $
            chrishamm administrators @BlueDust
            @bluedust It's probably the same reason, try to upgrade the other packages via sudo apt upgrade libpulse-mainloop-glib0 libpulse0 libpulsedsp pulseaudio pulseaudio-module-bluetooth pulseaudio-utils
            BlueDustundefined 1 Reply Last reply Reply Quote 1
            • BlueDustundefined
              BlueDust @chrishamm
              @chrishamm
              It seems odd if I am the only one to get this error. A while back I changed to the beta release, and then back to stable for 3.2. No other changes other then updating via apt get.
              pi@duet3:~ $ sudo apt upgrade libpulse-mainloop-glib0 libpulse0 libpulsedsp pulseaudio pulseaudio-module-bluetooth pulseaudio-utils
              Some packages could not be installed. This may mean that you have
              requested an impossible situation or if you are using the unstable
              distribution that some required packages have not yet been created
              or been moved out of Incoming.
              The following information may help to resolve the situation:
              The following packages have unmet dependencies:
               pulseaudio-module-bluetooth : Breaks: bluealsa but 0.13 is to be installed
              E: Broken packages
              pi@duet3:~ $
              pi@duet3:~ $ sudo apt-get update                                                          Hit:1 http://archive.raspberrypi.org/debian buster InRelease
              Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
              pi@duet3:~ $ sudo apt-get upgrade                                                         Reading package lists... Done
                pulseaudio-utils
              pi@duet3:~ $
              • BlueDustundefined
                BlueDust @chrishamm
                @chrishamm
                Again, thanks for helping me get the board upgraded to 3.3. I assume the left over files are not really needed in my use case with the Duet3 and not terribly worried unless someone tells me differently.
                  @bluedust You're welcome. I am pretty sure you got the first "held back" message because you downgraded from v3.3-rcX before and had to deliberately remove the duetpluginservice package, which is pulled in as a recommended dependency for DSF 3.3.
                  You need PulseAudio only if you want to have simple audio recording/playback. In your particular case I'd try to remove pulseaudio-module-bluetooth and bluealsa and see what happens when you try to upgrade then (sudo apt remove pulseaudio-module-bluetooth bluealsa followed by sudo apt upgrade).
                  • BlueDustundefined
                    BlueDust @chrishamm
                    @chrishamm
                    I have only used the Dev builds before 3.2 release came out. Once it was out I updated the Pi to use stable, and never went back (to non stable releases).
                    • BlueDustundefined
                      BlueDust @chrishamm
                      @chrishamm
                      Correct. I don't need audio for any reason on the Pi. It is only used to control the Duet3.
                      No more errors.
                      Thanks again for the help!
                      pi@duet3:~ $ sudo apt remove pulseaudio-module-bluetooth bluealsa
                      The following packages will be REMOVED:
                        bluealsa pulseaudio-module-bluetooth
                      0 upgraded, 0 newly installed, 2 to remove and 5 not upgraded.
                      After this operation, 460 kB disk space will be freed.
                      (Reading database ... 79681 files and directories currently installed.)
                      Removing bluealsa (0.13) ...
                      Removing pulseaudio-module-bluetooth (12.2-4+deb10u1) ...
                        libpulse-mainloop-glib0 libpulse0 libpulsedsp pulseaudio pulseaudio-utils
                      5 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                      Need to get 1,442 kB of archives.
                      After this operation, 8,192 B of additional disk space will be used.
                      Get:1 http://archive.raspberrypi.org/debian buster/main armhf libpulsedsp armhf 12.2-4+deb10u1+rpi3 [45.1 kB]
                      Get:2 http://archive.raspberrypi.org/debian buster/main armhf pulseaudio-utils armhf 12.2-4+deb10u1+rpi3 [75.5 kB]
                      Get:3 http://archive.raspberrypi.org/debian buster/main armhf pulseaudio armhf 12.2-4+deb10u1+rpi3 [1,039 kB]
                      Get:4 http://archive.raspberrypi.org/debian buster/main armhf libpulse-mainloop-glib0 armhf 12.2-4+deb10u1+rpi3 [37.0 kB]
                      Get:5 http://archive.raspberrypi.org/debian buster/main armhf libpulse0 armhf 12.2-4+deb10u1+rpi3 [246 kB]
                      Fetched 1,442 kB in 2s (830 kB/s)
                      (Reading database ... 79657 files and directories currently installed.)
                      Preparing to unpack .../libpulsedsp_12.2-4+deb10u1+rpi3_armhf.deb ...
                      Unpacking libpulsedsp:armhf (12.2-4+deb10u1+rpi3) over (12.2-4+deb10u1) ...
                      Preparing to unpack .../pulseaudio-utils_12.2-4+deb10u1+rpi3_armhf.deb ...
                      Unpacking pulseaudio-utils (12.2-4+deb10u1+rpi3) over (12.2-4+deb10u1) ...
                      Preparing to unpack .../pulseaudio_12.2-4+deb10u1+rpi3_armhf.deb ...
                      Unpacking pulseaudio (12.2-4+deb10u1+rpi3) over (12.2-4+deb10u1) ...
                      Preparing to unpack .../libpulse-mainloop-glib0_12.2-4+deb10u1+rpi3_armhf.deb ...
                      Unpacking libpulse-mainloop-glib0:armhf (12.2-4+deb10u1+rpi3) over (12.2-4+deb10u1) ...
                      Preparing to unpack .../libpulse0_12.2-4+deb10u1+rpi3_armhf.deb ...
                      Unpacking libpulse0:armhf (12.2-4+deb10u1+rpi3) over (12.2-4+deb10u1) ...
                      Setting up libpulse0:armhf (12.2-4+deb10u1+rpi3) ...
                      Setting up libpulsedsp:armhf (12.2-4+deb10u1+rpi3) ...
                      Setting up libpulse-mainloop-glib0:armhf (12.2-4+deb10u1+rpi3) ...
                      Setting up pulseaudio-utils (12.2-4+deb10u1+rpi3) ...
                      Setting up pulseaudio (12.2-4+deb10u1+rpi3) ...
                      Installing new version of config file /etc/pulse/daemon.conf ...
                      Installing new version of config file /etc/pulse/default.pa ...
                      Processing triggers for libc-bin (2.28-10+rpi1) ...
                      Processing triggers for dbus (1.12.20-0+deb10u1) ...
                      Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
                      Fetched 15.0 kB in 3s (5,415 B/s)
                      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                      pi@duet3:~ $
