    G28 Z Error: Z probe already triggered at start of probing move
    Firmware installation
    2.3k
    • Handymanpa54undefined
      Handymanpa54
      Hello All,
      There may be an answer to how to fix this error here someplace, but I'm so new to this I'm not sure where to Navigate to.
      I have a Duet wifi2 and running 3.2.2
      I'm updating my CR-10s The x and y axis work and hit end stops correctly, but z shows this error.
      G28 Z
      I think I have the Z motor and end stop wired the same as the x and y axis. Since I 'm so new to this I don't know the best way to resolve this.
      Help!
      • fcwiltundefined
        fcwilt @Handymanpa54
        @handymanpa54
        The error mentions a Z probe.
        Are you homing Z with a Z endstop or a Z probe?
        Thanks.
        Handymanpa54undefined 1 Reply Last reply Reply Quote 0
          Handymanpa54 @fcwilt
          @fcwilt
          Thanks.
          I'm homing with End_stop switch. At this time I don't have a z probe, Like BL touch or anything like that.
          • fcwiltundefined
            @handymanpa54 said in G28 Z Error: Z probe already triggered at start of probing move:
            @fcwilt
            Thanks.
            OK at this point we need to see all of your *.g configuration files.
            Please post them using the </> tag.
              @fcwilt config.g file```
              undefined
              ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Jun 22 2021 22:51:04 GMT-0400 (Eastern Daylight Time)
              M550 P"My Printer" ; set printer name
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
              M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
              M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X330 Y330 Z400 S0 ; set axis maxima
              M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
              M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
              M557 X15:215 Y15:195 S20 ; define mesh grid
              fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
              • fcwiltundefined
                @handymanpa54
                I reposted you config.g contents using the </> tag.
                We also need to see your homing files.
                Thanks.
                Handymanpa54undefined 3 Replies Last reply Reply Quote 0
                  @fcwilt Home z
                  undefined
                  G90                                            ; send absolute coordinates...
                  M83                                            ; ...but relative extruder moves
                  M584 X0 Y1 Z2 E3                               ; set drive mapping
                  M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                  M208 X0 Y0 Z0 S1                               ; set axis minima
                  M140 H0                                        ; map heated bed to heater 0
                  M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                  M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                  M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                  M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                  M563 P0 D0 H1 F0                               ; define tool 0
                  G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                  G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                  undefined
                    @fcwilt
                    undefined
                    ; homex.g
                    ; called to home the X axis
                    G91               ; relative positioning
                    G1 H2 Z5 F6000    ; lift Z relative to current position
                    G1 H1 X-335 F1800 ; move quickly to X axis endstop and stop there (first pass)
                    G1 H2 X5 F6000    ; go back a few mm
                    G1 H1 X-335 F360  ; move slowly to X axis endstop once more (second pass)
                    G1 H2 Z-5 F6000   ; lower Z again
                    G90               ; absolute positioning
                    undefined
                      @fcwilt
                      Home all
                      undefined
                      ; homeall.g
                      ; called to home all axes
                      G1 H1 X-335 Y-335 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                      G1 H2 X5 Y5 F6000       ; go back a few mm
                      G1 H1 X-335 Y-335 F360  ; move slowly to X and Y axis endstops once more (second pass)
                      G1 H1 Z-405 F360        ; move Z down stopping at the endstop
                      G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
                      ;G91                    ; relative positioning
                      ;G1 Z5 F100             ; lift Z relative to current position
                      ;G90                    ; absolute positioning
                      undefined
                        Phaedrux Moderator @Handymanpa54
                        Since you don't have a Zprobe at all you can actually comment out these lines entirely by adding a; in front of the line. That way they will be ignored by the firmware.
                        Your homeall looks to be using the endstop rather than a probe, so I'm not sure where the error is coming from exactly.
                        Does your homez have the same lines?
                        Can you send M119 and check the status of your endstops? Send it once with the switch clicked, and again with it not clicked.
                        Also for good measure, please send M122 and M98 P"config.g" in the gcode console and post the responses here.
                        Handymanpa54undefined 5 Replies Last reply Reply Quote 0
                          Handymanpa54 @Phaedrux
                          @phaedrux said in G28 Z Error: Z probe already triggered at start of probing move:
                          6/23/2021, 9:03:23 PM M119
                          Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: at min stop
                          6/23/2021, 9:05:37 PM M122
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
                          Board ID: 0JD0M-9P6M2-NW4SS-6JKD2-3SD6M-9VZ7L
                          Used output buffers: 3 of 24 (13 max)
                          Static ram: 23460
                          Dynamic ram: 73168 of which 76 recycled
                          Never used RAM 15376, free system stack 121 words
                          Tasks: NETWORK(ready,164) HEAT(blocked,308) MAIN(running,453) IDLE(ready,20)
                          Owned mutexes: WiFi(NETWORK)
                          Last reset 00:17:39 ago, cause: power up
                          Last software reset at 2021-06-23 17:14, reason: User, GCodes spinning, available RAM 15412, slot 1
                          Error status: 0x00
                          Aux0 errors 0,0,0
                          MCU temperature: min 16.5, current 27.5, max 28.3
                          Supply voltage: min 23.8, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                          Driver 0: position 1200, standstill, SG min/max 107/300
                          Driver 1: position 1200, standstill, SG min/max 104/310
                          Driver 2: position 0, standstill, SG min/max not available
                          Driver 5: position 0
                          Driver 6: position 0
                          Driver 7: position 0
                          Driver 8: position 0
                          Driver 9: position 0
                          Driver 10: position 0
                          Driver 11: position 0
                          Date/time: 2021-06-23 21:05:36
                          Cache data hit count 1298563318
                          Slowest loop: 10.66ms; fastest: 0.21ms
                          === Storage ===
                          Free file entries: 10
                          SD card longest read time 3.9ms, write time 2.1ms, max retries 0
                          DMs created 83, maxWait 557224ms, bed compensation in use: none, comp offset 0.000
                          === MainDDARing ===
                          Scheduled moves 17, completed moves 17, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                          === AuxDDARing ===
                          Segments left: 0
                          Movement lock held by null
                          HTTP is idle in state(s) 0
                          Telnet is idle in state(s) 0
                          File is idle in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Trigger is idle in state(s) 0
                          Queue is idle in state(s) 0
                          LCD is idle in state(s) 0
                          Daemon is idle in state(s) 0
                          Code queue is empty.
                          === Network ===
                          Slowest loop: 21.15ms; fastest: 0.00ms
                          HTTP sessions: 1 of 8
                          • WiFi -
                            Network state is active
                            WiFi firmware version 1.25
                            WiFi MAC address f4:cf:a2:e2:10:76
                            WiFi Vcc 3.37, reset reason Turned on by main processor
                            WiFi flash size 4194304, free heap 25360
                            WiFi IP address 192.168.0.11
                            WiFi signal strength -75dBm, mode 802.11n, reconnections 0, sleep mode modem
                            Clock register 00002002
                          6/23/2021, 9:06:40 PM M98 P"config.g"
                          HTTP is enabled on port 80
                          FTP is disabled
                          TELNET is disabled
                          ; homez.g
                          ; called to home the Z axis
                            @phaedrux
                            My homez.g had other text so I copy and pasted in what you showed. Still the same results.
                            Then I toggled the x axis with my finger and saw the lite go on and off.I tried the same on the Z axis, but the lite goes dim but not all the way off!!!
                            Mark
                              @Phaedrux edrux
                              I noticed in the dashboard window Status shows Z_probe with red and 988? I don't know if that is normal?
                                @phaedrux
                                I got z to show homed, so I was able to use machine movement to give +5 but it moves down towards the bed and -5 makes it move away from the bed.
                                  Then you'll need to change the direction of rotation for the Z axis.
                                  Change S0 to S1 in config.g
                                  And this is with the endstops both clicked and unclicked? Or just Z?
                                  Sounds like a wiring issue. Bad crimp maybe? Bad switch?
                                  If you commented out those probe lines I'm not sure what it would show there or why, but it's not really relevant at all when using an endstop instead of a probe.
                                  While we're at it might as well update the firmware.
                                  Download this zip file and upload it to the System tab in DWC.
                                    @phaedrux
                                    hi, the Z axis travels in the proper direction now. I changed from S1 to S0. I still had the problem with the limit switch. That turned out to be 10k resistor on the limit switch board. I get it to stop on home now. I just need some code so that it will do a double kiss of the z limit switch and the second one should be slower so it can be more exact.
                                    I'm actually making progress.
                                    Thanks for your help!
                                      You can see an example of that in the other homing files.
                                      Sounds like you're making some progress now.
                                        @phaedrux I'm trying to get paneldue working and proper code for z home.
                                        6/24/2021, 3:09:26 PM 	Download of PanelDueFirmware-3.3.0-rc1-5.0i-7.0i.bin successful after 1s
                                        6/24/2021, 3:08:34 PM 	Error: M997: File 0:/firmware/PanelDueFirmware.bin not found
                                        6/24/2021, 3:08:34 PM 	M997 S4
                                        6/24/2021, 3:07:07 PM 	Error: Probe already triggered at start of probing move
                                        6/24/2021, 3:06:55 PM 	G28
                                        6/24/2021, 3:04:29 PM 	Error: M997: File 0:/firmware/PanelDueFirmware.bin not found
                                        6/24/2021, 3:04:28 PM 	M997 S4
                                        undefined
                                          @phaedrux
                                          G1 H1 Z-405 F1200        ; move Z down stopping at the endstop
                                          G1 H1 Z-405 F260        ; move Z down stopping at the endstop
                                          undefined
                                            @phaedrux
                                            Paneldue display is live but touch keys don't work.
