    Duet 3 3HC Expansion board firmware update.
    Firmware installation
    • CSLTMundefined
      CSLTM
      I've managed to install the new V3.3 firmware on my Duet 3 however my expansion board is on V3.0.
      I've tried moving the updated firmware for the expansion board onto the SD card however the option to install it doesn't come up like it did for the toolboards.
      Any help appreciated.
      Many thanks,
      Tom
        jay_s_uk @CSLTM
        @csltm use M997 Bx where x is the CAN number
        CSLTMundefined 2 Replies Last reply Reply Quote 1
        • CSLTMundefined
          CSLTM @jay_s_uk
          @jay_s_uk said in Duet 3 3HC Expansion board firmware update.:
          M997
          @jay_s_uk You've done it again! Cheers chap!
          • CSLTMundefined
            CSLTM @jay_s_uk
            @jay_s_uk
            Hi Jay,
            Maybe that didn't quite work.
            The only thing that the expansion is running is the tool pin for the tool changer mechanism.
            These are the errors I get, I'm still unable to home 'C' which is what that pin is called.
            Cheers,
              jay_s_uk @CSLTM
              @csltm yea, looks like the expansion board hasn't been upgraded.
              Which command did you send?
              Is it on CAN address 1?
              Whats the output of M122 B1? (assuming 1 is the CAN number)
              CSLTMundefined 1 Reply Last reply Reply Quote 0
              • CSLTMundefined
                CSLTM @jay_s_uk
                @jay_s_uk
                I sent M997 B1 and upgraded the board to 3.2. Couldn't find a bin file for 3.3 expansio board firmware.
                The results of M122 are as below.
                m122 b1
                Diagnostics for board 1:
                Duet EXP3HC firmware version 3.2 (2021-01-05)
                Bootloader ID: not available
                Never used RAM 154848, free system stack 200 words
                HEAT 75 CanAsync 94 CanRecv 87 TMC 64 MAIN 309 AIN 257
                Last reset 00:00:23 ago, cause: software
                Last software reset data not available
                Driver 0: position 0, 100.0 steps/mm, standstill, reads 45547, writes 18 timeouts 0, SG min/max 0/0
                Driver 1: position 0, 80.0 steps/mm, standstill, reads 45558, writes 11 timeouts 0, SG min/max 0/0
                Driver 2: position 0, 80.0 steps/mm, standstill, reads 45561, writes 11 timeouts 0, SG min/max 0/0
                Moves scheduled 0, completed 0, in progress 0, hiccups 0
                No step interrupt scheduled
                VIN: 24.2V, V12: 12.2V
                MCU temperature: min 50.2C, current 50.2C, max 50.2C
                Ticks since heat task active 210, ADC conversions started 23702, completed 23700, timed out 0
                Last sensors broadcast 0x00000000 found 0 213 ticks ago, loop time 0
                CAN messages queued 72, send timeouts 0, received 133, lost 0, free buffers 36
                Cheers!
                  jay_s_uk @CSLTM
                  @csltm The 3.3 firmware is here https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet3Firmware_EXP3HC.bin
