    Help straighten me out on pin naming
    609
    • kb58undefined
      kb58
      I'm having trouble understanding how user-defined pin names associate with a physical connector. For example, M574 might assign: X1 S1 P"X_endstop". The issue is that this assignment doesn't know where I'm plugging in the endstop switch. Where does X_endstop get assigned to a particular connector/io pin? I haven't seen it explained in any of the guides. Thanks in advance.
      peter247undefined 1 Reply Last reply Reply Quote 0
      • Javajoeukundefined
        Javajoeuk
        what board do you have and what firmware do you have on it?
        kb58undefined 1 Reply Last reply Reply Quote 0
        • kb58undefined
          kb58 @Javajoeuk
          @javajoeuk
          Oh, sorry, first post. Firmware is 3.3 and board rev is 1.01.
            Javajoeuk
            duet 3 or duet 2
            • kb58undefined
              kb58 @Javajoeuk
              @javajoeuk Duet3
              • peter247undefined
                peter247 @kb58
                @kb58 if you are on a duet 2 wifi there are clear x , y , z , e0 , e1 end stop ports , and x , y , z , e0 , e1 stepper motor ports
                On duet 3 it is more like motor 0 , 1 , 2 , 3 , 4 and io_0 ins and outs.
                duet 3 mini or full
                Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                kb58undefined 2 Replies Last reply Reply Quote 0
                  Javajoeuk
                  https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches
                  • kb58undefined
                    kb58 @peter247
                    Duet 3 "full"
                    • kb58undefined
                      kb58 @peter247
                      @peter247 So there's an internal association between, say, motor 1 and io_1, without explicitly having to say as much, yes?
                      peter247undefined resamundefined 2 Replies Last reply Reply Quote 0
                      • peter247undefined
                        peter247 @kb58
                        @kb58 https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram
                        not motor 0 can be anything so can io_0 , it can be a end stop filament out sensor or trigger , it is all on you to set how it works.
                        • kb58undefined
                          kb58
                          This post is deleted!
                          • peter247undefined
                            peter247 @kb58
                            @kb58 it is not named that is on duet 2
                              Javajoeuk
                              no i dont think so you have to tell it which pin you want it to use
                              • peter247undefined
                                peter247 @Javajoeuk
                                @javajoeuk Yes you tell it which pin to use , but it can be any pin to do any job.
                                • kb58undefined
                                  kb58 @peter247
                                  @peter247 Okay, so I'm still not seeing it. If any pin can be anything, I'm back to asking the same question, that naming an end stop is only half the picture, that somewhere it has to get "pointed" to the physical connector that I'm plugging that switch into. Sorry for being dense, but I'm an engineer...
                                  • resamundefined
                                    resam @kb58
                                    @kb58 look here for a full list of pin names:
                                    https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Duet_3_MB6HC_pin_names
                                    and the wiring an hardware overview:
                                    https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram#Section_Revision_1_0_and_1_Num_01
                                    and the M574 for RRF3 help:
                                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3
                                    kb58undefined 2 Replies Last reply Reply Quote 1
                                    • kb58undefined
                                      kb58 @resam
                                      @resam I know about the pin names, but a name is just text, it's not hardwired to anything. If I have: M574 X1 S1 P"X_endstop", what connector is "X_endstop" looking at?
                                      resamundefined 1 Reply Last reply Reply Quote 0
                                      • kb58undefined
                                        kb58 @resam
                                        @resam Or, are you saying that I have to use M574 X1 S1 P"io1.in", and that I'm not free to rename them? That seems doubtful because io1.in is just a text string, no?
                                        • peter247undefined
                                          peter247 @kb58
                                          @kb58 This is my set up .
                                          M574 X1 S1 P"!io0.in"                          ; configure active-high endstop for low end on X via pin xstop
                                          M574 Y2 S1 P"!io1.in"                          ; configure active-high endstop for low end on Y via pin ystop
                                          ;M574 Z1 S2
                                          M558 P9 C"io2.in" H2 F100 T8000 A5		        ; set Z probe type to bltouch and the dive height + speeds
                                          M950 S0 C"io2.out"							    ; create servo pin 0 for BLTouch
                                          G31 P500 X 30 Y 55 Z 1.4                        ; set Z probe trigger value, offset and trigger height
                                          M557 X60:240 Y60:240 S30
                                          But I could have used io1.in for the X stop if I had configured it that way.
                                          • kb58undefined
                                            kb58 @peter247
                                            @peter247 Ah, okay, so only predefined pin names can be used.
