    New test firmware 1.19+4 and DuetWiFiServer 1.19+1
    Firmware installation
    8
    36
    3.9k
    • DocTruckerundefined
      DocTrucker
      Is the "File Information" section of the web page getting information from the firmware or purely on the web server side of things? How is it identifying layers if on the firmware? Mine is currently reporting 0.35mm layer thickness, which is only the first layer. I have however stripped a lot of code out of the gcode file to stop it using heat, and might have accidentally stripped what it is using to identify layers!
      Edit: Nuts. Just seen the rc5 release… Will upgrade after testing the time estimation.
        DocTrucker
        Late report on the build time estimation! This is a test build with no heat. Works fine for me.
        Actual build time: 2hr20m36s
        Time to run the simulation: 0hr5m30s
        Predicted build time: 2hr21
        25.6 times quicker than build time on a Duet 0.6. I'll run a similar test on the DuetWifi at home soon. Guess I could just run the simulation and use this machine's config file temporarily.
        Edit: Running the above again in 1.19+5 (2017-08-30) Will report on that thread.
          Please use the 1.19.2 release from https://github.com/dc42/RepRapFirmware/releases, not the older +5 release.
          The file information is provided by the firmware.
          The Duet WiFi has a faster processor than the 0.6 so it should run the simulation faster.
            DocTrucker
            Thanks. Will do - after the current test has completed. Didn't spot the 19.2 release.
            • Jareryundefined
              Jarery
              @dc42:
              If the WiFi module has disconnected from your router then it should write a message to USB saying so and giving progress information about the reconnection attempt. This was new in 1.19.2.
              Doing a mesh bed calibration it disconnects mid way through. No output or messages on MacPronterface which was connected via serial at the time. I get no messages via serial at all unless I type a command to get a response.
              On the MacPronterface if I do a M122 I get the following Wifi section:
              Network state is running
              WiFi firmware version 1.19.2
              WiFi MAC address 5c:cf:7f:a4:a1:64
              WiFi Vcc 3.13, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 39840
              WiFi IP address 192.168.2.54
              WiFi signal strength -38dBm
              Reconnections 0
              HTTP sessions: 1 of 8
              Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              Trying to reconnect via browser that was open previously is " Error, Could not establish a connection to the Duet firmware! Please check your settings and try again" repeatedly, unable to reconnect.
              Opening a new browser, to check Router (Asus AC3100) I see its connected and assigned an IP. Clicking on IP within router browser its unable to open a new window, it just times out.
                That sounds like a different failure mode (connection stable but messages not getting through). Try enabling Webserver and Network debugging using M111, then see whether the failed attempts to open a session in a browser give rise to any debug messages in Pronterface.
                • Jareryundefined
                  Jarery
                  heres whats the serial connection reports after after a disconnect :
                  HTTP connection accepted
                  Found responder
                  Received 394 bytes
                  Sending reply, file = no
                  HTTP req, command words { GET /rr_status HTTP/1.1 }, parameters { type=3 }
                  New conn on socket 0 for local port 80
                  Found responder
                  Received 394 bytes
                  Found responder
                  Received 394 bytes
                  Class Network spinning.
                    According to that, the Duet appears to be behaving correctly. Can you get a Wireshark trace of the network traffic?
                    • Jareryundefined
                      Jarery
                      That is beyond my current level of network troubleshooting ability…
                      Once it disconnects, My web browser just repeatedly states it cannot connect, and the serial output is :
                      File DuetWifi_Wiring_Box.gcode print time was 5h 8m
                        Sounds like the WiFi module has stopped responding. Sending M552 S-1 to reset it followed by M552 S1 to reconnect may get it working again, but that doesn't solve the problem.
                        • Adamfilipundefined
                          Adamfilip
                          Noticed that my PanelDue 7 flashes now every second or so. didnt do this before.. not sure whats causing it.
                            If you mean the backlight flashes on and off, or isn't a steady brightness, that's common if you try to power a 7" PanelDue from USB power only. A standard 500mA USB port can't provide enough current for the 7" display.
                            • Jareryundefined
                              Jarery
                              @dc42:
                              This helps occasionally.
                              After initial power on, once connected it seems to remain connected until I print. I have yet to have a print go beyond 15-20 min and stay connected since the update from 1.18
                              I have a macro that disconnects wifi and reactivates so after it loses connection I can attempt to reacquire. I have maybe 50-50 success rate. Many times, doing this still I am unable to require web browser. The only sure fire way is to power completely off, unplug serial if connected, and power back up. Even if i do reacquire connection mid print using this method (macro not reboot) it disconnects again after a period of time.
                              My router shows ip assigned the entire time.
                              Safari, chrome, etc, browser has no change.
                                If you run M122 after a print, what MaxReps value does it give?
                                • Jareryundefined
                                  Jarery
                                  Tested during a print last night.
                                  Disconnected 5 or 6 times I believe. Near the end of the print after I reconnected (by using M552 S-1, M552 S1) it stated MaxReps 5.
                                  After print completed when I connect and do a M122 it says MaxReps 4.
                                    That value is nice and low, so it looks like excessive step pulse rate isn't a factor.
