    Duet 3 6HC dead, I is sad (fixed!)
    670
      droftarts administrators @kb58
      @kb58 said in Duet 3 6HC dead, I is sad (fixed!):
      Apparently the existing file on the SD card is first erased, and then the edited file takes its place. If the write fails, the controller has nothing to fall back on, so config.g has to be rewritten via other means.
      That’s not quite right. If there is no config.g, the firmware will try to execute config.g.bak. In your case, there was a config.g, it’s just it was empty. So it didn’t execute config.g.bak.
