    Cheapest WiFi Webcam: ESP32 + OV2640 camera
    Duet Web Control
    • jaschkopfundefined
      jaschkopf
      Re: Cheap WiFi Webcam: ESP32 + OV2640 camera
      Hey,
      I found this topic and was quite interested to add a camera to my Duet 2 Wifi.
      From an old project I hat an (AI-Thinker) ESP32-Cam module lying around. It is about 8€ at ebay shipping from Germany. If you order from china the module is quite cheaper.
      I found this tutorial to convert the ESP32-Cam to a surveilance camera, but the stream works for duet very well.
      https://randomnerdtutorials.com/esp32-cam-video-streaming-web-server-camera-home-assistant/
      So follow the tutorial, insert your wifi credentials at line 28+29 and change the resolution at line 230. Forme these settings worked very good with DWC:
      if(psramFound()){
         config.frame_size = FRAMESIZE_SVGA;
         config.jpeg_quality = 10;
         config.fb_count = 2;
       } else {
      Here you can find some information about the possible settings:
      https://randomnerdtutorials.com/esp32-cam-ov2640-camera-settings/
      At DWC you just have to past the IP adress at Webcam-URL field like this: http://192.168.178.153/
      After flashing start the serial monitor in Arduino IDE to find out your IP.
      That's all 😉
      dc42undefined 1 Reply Last reply Reply Quote 2
        dc42 administrators @jaschkopf
        @jaschkopf thanks for sharing this!
        • gloomyandyundefined gloomyandy referenced this topic
