Printing off SD card stops and reboots
  • Building a new printer and my first one using a Duet Wifi
    While printing off the SD card, I've had it reset two or three times randomly now. I do not think it is the G-code as the first time I reprinted the same file perfectly fine.
    [[language]]
    M122
    Used output buffers: 3 of 32 (13 max)
    RepRapFirmware for Duet WiFi version 1.19 running on Duet WiFi 1.0
    Board ID: 08DDM-9FAM2-LW4SD-6JTD8-3SS6N-TMYHZ
    Static ram used: 21176
    Dynamic ram used: 95976
    Recycled dynamic ram: 1632
    Stack ram used: 1304 current, 4992 maximum
    Never used ram: 7296
    Last reset 00:10:21 ago, cause: software
    Last software reset reason: User, spinning module GCodes, available RAM 3224 bytes (slot 4)
    Software reset code 0x5003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0040080f, BFAR 0xe000ed38, SP 0x2001f504
    Stack: 00434fcb 00008196 ffffffe9 00051051 00081111 40080000 00008196 20003688 0042fceb 004338b0 61000200 42eeea80 00000000 00000000 00000000 00000000 00000000 4b5c3d5e
    Error status: 0
    Free file entries: 10
    MCU temperature: min 28.3, current 28.5, max 28.9
    Supply voltage: min 24.1, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0
    Driver 0: stalled standstill
    Driver 1: stalled standstill
    Driver 2: stalled standstill
    Driver 3: stalled standstill
    Driver 4: standstill
    Date/time: 2017-08-29 02:39:06
    Slowest main loop (seconds): 0.005859; fastest: 0.000061
    MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
    Scheduled moves: 0, completed moves: 0
    Bed compensation in use: none
    Bed heater = 0, chamber heater = -1
    Heater 1 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    Network state is running
    WiFi firmware version 1.19
    WiFi MAC address 5c:cf:7f:ef:4d:3e
    WiFi Vcc 3.16, reset reason Turned on by main processor
    WiFi flash size 4194304, free heap 39032
    WiFi IP address 192.168.1.165
    WiFi signal strength -65dBm
    HTTP sessions: 2 of 8
    Socket states: 2 0 0 0 0 0 0 0
    Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
    I might try 1.19.1 tomorrow. Too late to do anything now.
    The M122 report indicates that the firmware got stuck in a loop, possibly (but not definitely) while trying to send something to USB, and the software watchdog time out and caused the reset.
  • Any idea how to prevent this from happening again? I don't have anything plugged into the USB, does it still try to send data over USB with nothing connected?
    Unless you enable debugging using M111 with a nonzero S parameter, having nothing connected via USB should never be a problem.
