Require assistance with BLTouch
  • Installed BLTouch on Duet 0.8.5 for my CoreXY…
    In the thread: https://www.duet3d.com/forum/thread.php?id=459
    I read that I should add these in
    Deployprobe.g macro contains the line M280 P3 S10 I1 to deploy the BLTouch probe
    Retractprobe.g macro contains the line M280 P3 S90 I1 to retract the BLTouch probe
    Deploy and Retract macros are added to bed.g and homing macros
    However, I do not have those two files…
    I redid the RRF Configuration tool. I click "deploy/retract probe". fill everything else. Once everything is done I choose Finish but it freezes on generating...
    Thanks you
    You have to create those two files yourself, which you can do in the System Files Editor of Duet Web Control.
    If you have a popup blocker configured in your browser, disable it when running the configuration tool.
Locked
