    Duet3: Wiring Hotend and fans with common V_FUSED
    • JNBundefined
      JNB
      Hey,
      I have a problem and didn't really understand where it derives from.
      I'm setting up my Tenlog Hands 2 with a Duet 3 6HC and a 3HC.
      The default hotend / extruder combination has a common trace for the hotend 24V supply and the fan's 24V power supply.
      I connected the hotend to out0 on the 3HC and the fans to out7 & out8 on the 3HC with the jumper set to V_FUSED.
      So looking on the wiring diagram they should also have common V_FUSED on the 3HC and the GND connection switched by a FET (PWM etc.)
      But the Duet alsways resets if I enable the heater while the fans are plugged in.
      If I don't plug in the fans everything works as expected....
      Can someone tell me why this is happening and how to connect this board properly to the extruder?
      Thanks
      JNB
      JNBundefined 1 Reply Last reply Reply Quote 0
      • JNBundefined
        JNB @JNB
        As stated in this thread, the problem is solved after swapping the cables connected to the 3HC on the out0 / out1 headers.
