    3HC pins issue (io2.out) (RRF 3.3)
    • chernogorskyundefined
      chernogorsky
      Hi, I try configuring zprobe on 3hc,
      and receive strange behavior
      io0.out does not work (no error message, just do not drive servo). may be not related to the case.
      io1.out - works like a charm
      io2.out - I receive the following error M950: Unknown pin name 'io2.out'
      steps to reproduce
      connect 3hc with proper number (let's say 10)
      than
      M950 S0 C"10.io2.out"
      M558 P9 C"10.io2.in" I0 R1 H3
      m122 b10
      Diagnostics for board 10:
      Duet EXP3HC firmware version 3.3 (2021-06-15 16:12:41)
      Bootloader ID: not available
      Never used RAM 158712, free system stack 4392 words
      Tasks: Move(notifyWait,0.0%,160) HEAT(delaying,0.0%,88) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,0.0%,82) CanClock(notifyWait,0.0%,71) TMC(notifyWait,7.3%,63) MAIN(running,91.4%,438) IDLE(ready,0.0%,39) AIN(delaying,1.3%,263), total 100.0%
      Last reset 00:11:50 ago, cause: software
      Last software reset data not available
      Driver 0: position 0, 837.0 steps/mm, standstill, reads 52651, writes 19 timeouts 0, SG min/max 0/0, steps req 0 done 0
      Driver 1: position 0, 60.0 steps/mm, standstill, reads 52654, writes 16 timeouts 0, SG min/max 0/0, steps req 0 done 0
      Driver 2: position 0, 80.0 steps/mm, standstill, reads 52660, writes 11 timeouts 0, SG min/max 0/0, steps req 0 done 0
      Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
      Peak sync jitter 0/17, peak Rx sync delay 179, resyncs 0/0, no step interrupt scheduled
      VIN: 24.1V, V12: 12.2V
      MCU temperature: min 37.0C, current 37.9C, max 38.3C
      Ticks since heat task active 102, ADC conversions started 710206, completed 710206, timed out 0, errs 0
      Last sensors broadcast 0x00000800 found 1 107 ticks ago, loop time 0
      CAN messages queued 8226, send timeouts 0, received 9071, lost 0, free buffers 37, min 37, error reg 100000
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
      • kb58undefined
        kb58
        Did you enable usage (whether it's present or not) of a PanelDue? If so, the firmware assumes that it's connected to io0.
        If you want more detailed answers, please provide your config.g file, pasted in using the </> tag above the Reply window.
        Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
          Can you post your full config.g and the results of M122 for your mainboard as well?
          BLtouch i assume?
            dc42 administrators @Phaedrux
            Only PWM-capable ports support servos. See https://duet3d.dozuki.com/Wiki/Duet_3_Expansion_Hardware_Overview#Section_IO for which ports are PWM-capable.
            chernogorskyundefined 1 Reply Last reply Reply Quote 0
              chernogorsky @dc42
              Thanks, I miss that part from the documentation.
              So, all goes as expected than
                dc42 administrators @chernogorsky
                @chernogorsky said in 3HC pins issue (io2.out) (RRF 3.3):
                Except for the unknown pin message.
