    Tool board firmware update fails
    Firmware installation
    • kb58undefined
      kb58
      My setup:
      Duet 3 6HC, v3.3 firmware
      Toolboard v1.1, unknown firmware version
      Confirmed that Duet3Firmware_TOOL1LC.bin is on the SD drive, the toolboard LED is blinking slowly, showing connectivity, and confirmed that the v1.1 tool board is communicating:
      M115 B121
      "Duet TOOL1LC firmware version 3.3beta2+2 (2021-04-16 13:48:06)"
      Attempted an update:
      M997 B121
      "Error: M997: Firmware file Duet3Firmware_TOOL1LC.bin not found"
      Searched and found nothing indicting why this would fail.
      As an aside, I can't tell if the firmware even needs updating, because I don't know how to query the onboard firmware version, or what the latest is.
      Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
        jay_s_uk @kb58
        @kb58 if you have it in the sys folder, put it in a folder called firmware in the root of the SD card and vice versa.
        • kb58undefined
          kb58
          Oh, snap! Yes, you reminded me that new firmware needs to be in /Firmware. Fixed, and thank you, sir!
