Dual z Stop and Piezo Bed Level
If you want to do it step by step, that's fine, I just wondered.
I have also done the conversion to RRF3 by hand and really learned a lot.
But I would still recommend to do as much as possible with the tool, even if you only take it as a reverence to compare... -
@diy-o-sphere I'm just about to create another one with the tool this time even with piezo settings am curious how the same looks
@DIY-O-Sphere the newly created cfg looks totally different hope that this looks better and that I'm not on the wrong track. and yes I have to insert m671 and then also that in the bed.g . furthermore I have to look at what the manufacturer makes for information on M558
the whole thing I will do tomorrow
While the configurator tool and many folks put the M671 command in config.g I put it it bed.g because it is related to the operation of bed.g and nothing else.
It also means if I need to change M671 I edit bed.g and the next time I do G32 the new M671 settings take effect - no need to re-boot the printer to cause config.g to be processed again.
It is just my personal preference and it doesn't change the behavior of bed leveling.
Also remember to set the Z=0 datum (with a single G30) after leveling the bed.
