    Control of pneumatic selenoid
    • kj3dundefined
      kj3d
      I am using two solenoids, one is simply configured as a switch (on / off) Its function is simple, it switches air flow onto a brake, when air is on the brake is off. If its off the brake stops a ball screw rotating. Ideally I would like to switch air on before the command is sent to move the ball screw, but if power fails the ball screw brake to apply.
      The second is a PWM controlled flow valve that will replace a conventional cooling fan.
      My question is how is it best to configure these on an 6HC motherboard - ideally out7 and out8 would be good. Or alternatively please suggest what is best? With regards the simple on off solenoid the unit has a LED across the supply, do I need an additional flyback diode?
      kb58undefined 1 Reply Last reply Reply Quote 0
      • kb58undefined
        kb58 @kj3d
        @kj3d Well first off, what voltage do the solenoids run on, and what current do they draw. Flyback diodes are always a good thing, but they may be there already.
        Scratch-built 350mmx350mm coreXY, linear rails, ballscrews, 3 Z axis, Duet3 6HC, v3.3, Tool Board v1.1, BondTech LGX + Mosquito hot end
        kj3dundefined 1 Reply Last reply Reply Quote 0
        • kj3dundefined
          kj3d @kb58
          @kb58
          Both the solenoid and flow valve are 24v - the board
          jumpers are configured to supply 24v. Approx. 100ma each at 24v
            dc42 administrators @kj3d
            @kj3d the MB6HC has flyback diodes built-in to all OUT ports except OUT0. So you don't need to add an external one.
            • kj3dundefined
              kj3d @dc42
              Thanks - thats good to know. problem resolved and board working very well!!
