    Now, DWC SBC is supported natively in Repetier Server
    Duet Web Control
    • Marcossfundefined
      Marcossf
      From today, DWC SBC is supported natively in Repetier Server version 1.1.0.
      Is the Repetier Server first support for DuetControlServer as connection method. It requires RRF version 3.3 or newer. There's an RPI image (V26) with both systems preinstalled in their website.
      Both the DWC and the Repetier Server web environment are maintained simultaneously, accessible through different ports.
      I hope you find it interesting.
      oliofundefined 1 Reply Last reply Reply Quote 4
      • oliofundefined
        oliof @Marcossf
        @marcossf cool! For the unitiated, what does this mean? Repetier Server can be used as an alternate frontend to DWC?
        Marcossfundefined 1 Reply Last reply Reply Quote 1
        • Marcossfundefined
          Marcossf @oliof
          @oliof Yes, its a different frontend that has some usefull things DWC still haven't (user permits and passwords protection, network control, easy usage for unskilled personel, timelapse and extensive reporting, repositories....)
          All without loose any of trusty DWC usage.
