    What could have automagically changed my config-override.g file?
    • Wernerundefined
      Werner
      Hi Guys, In diagnosing my last issue of a clogged nozzle I somehow managed to get my config-override.g file changed. I just have, no idea how I did that? I must have issued a command in the console not knowing what I had done?
      ; Delta parameters
      M665 L409.530 R196.400 H335.150 B380.0 X0.000 Y0.000 Z0.000 (This H335.00 got turned into a 330.00)
      M666 X0.000 Y0.000 Z0.000 A0.00 B0.00
      Any idea how else this could have happened?
      Thanks for the help!
      Werner
      Werner Berry
      Designer-builder, BerryBot3D Pro
        The only time that config-override.g gets changed is when you run M500.
        • Wernerundefined
          Werner
          Thanks, David I think I could have done that!
          Thanks, Buddy! Have a great day!
          Werner
          Werner Berry
