    Need help with Ender-6 core xy motor movement
    Using Duet Controllers
    1.8k
    • davidewenundefined
      davidewen
      I'm installing a Duet 3 mini 5+ on an Ender-6
      X homes in the wrong direction
      Y homes correctly
      (at least for the Ender-6)
      Both motors are at the back corners
      X is back left
      Y is back right
      Endstops are at max positions
      X is on the right side
      Y is at the back right
      Checking the motor movement per:
      https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
      using
      G91
      G1 H2 X10 F3000 (carriage moves diagonal left and back)
      G1 H2 Y10 F3000 (carriage moves diagonal left and front)
      config.g attached
      config(1).g
      peter247undefined 1 Reply Last reply Reply Quote 0
      • peter247undefined
        peter247 @davidewen
        @davidewen
        My guess is try :
        M569 P0.0 S1
        M569 P0.1 S1
        then
        M569 P0.0 S0
        M569 P0.1 S0
        then is trial and error until you find it turning in the right direction .
        Just make sure that
        G91
        G1 H2 X10 F3000 ; goes right
        G1 H2 Y10 F3000 : goes towards the back
        Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
        davidewenundefined 1 Reply Last reply Reply Quote 0
          davidewen @peter247
          @peter247
          Thanks for the response.
          I've tried these configs.
          M569 P0.0 S0 ; physical drive 0.0 goes backwards
          M569 P0.1 S1 ; physical drive 0.1 goes forwards
          Y homes correctly
          X homes towards Y front
          M569 P0.1 S0 ; physical drive 0.1 goes backwards
          X homes towards Y endstop in rear
          X homes correctly
          David
          peter247undefined 2 Replies Last reply Reply Quote 0
          • peter247undefined
            peter247 @davidewen
            @davidewen said in [Need help with Ender-6 core xy motor movement]
            Just make sure it is moving correct .
            You may have problem with the homing files or other configs .
            • peter247undefined
              peter247 @davidewen
              @davidewen
              post homeall.g
                davidewen @peter247
                @peter247
                homeall.g attached
                homeall.g
                • peter247undefined
                  peter247 @davidewen
                  @davidewen
                  ; homeall.g
                  ; called to home all axes
                  ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jul 23 2021 13:25:10 GMT-0700 (Pacific Daylight Time)
                  G91                  ; relative positioning
                  G1 H2 Z5 F12000      ; lift Z relative to current position
                  G1 H1 X255 Y255 F900 ; move quickly to X or Y endstop and stop there (first pass)
                  G1 H1 X255           ; home X axis
                  G1 H1 Y255           ; home Y axis
                  G1 X-5 Y-5 F12000    ; go back a few mm
                  G1 H1 X255 F450      ; move slowly to X axis endstop once more (second pass)
                  G1 H1 Y255           ; then move slowly to Y axis endstop
                  G90                  ; absolute positioning
                  G1 X47 Y15 F12000    ; go to first bed probe point and home Z
                  G30                  ; home Z by probing the bed
                  ;G91                 ; relative positioning
                  ;G1 Z5 F200          ; lift Z relative to current position
                  ;G90                 ; absolute positioning
                  Confused , why are you lift the tool head , homing twice , lower the tool head and homing again .
                  M913 X50 Y50 Z50 ; set X Y Z motors to 50% of their normal current
                  G1 H2 Z5 F6000    ; lift Z relative to current position
                  G1 H1 X 330 F3000 ; move quickly to X axis endstop and stop there (first pass)
                  G1 H1 Y 330 F3000 ; move quickly to Y axis endstop and stop there (first pass)
                  ;G1 H2 Z-5 F6000   ; lower Z again
                  M913 X100 Y100 Z100 ;
                  This is my X Y part of homeall.g
                    davidewen @peter247
                    @peter247
                    Peter,
                    This is all from the RRF Config Tool. https://configtool.reprapfirmware.org
                    I have not written any of the code.
                    I'm guessing that is for the EZAble Z-probe. Similar to the Prusa z-probe.
                    • peter247undefined
                      peter247 @davidewen
                      @davidewen Homeall.g is crazy but it still should home in the right direction .
                      Have you tried swapping the x , y stepper motors wires and tried the 4 motor possibilities ?
                        davidewen @peter247
                        @peter247
                        I have not swapped wires.
                        Correct me if I'm wrong, but isn't changing motor direction the same as changing the wires? So that would be redundant.
                        • peter247undefined
                          peter247 @davidewen
                          @davidewen True , but you are also changing X , Y to Y , X
                          I don't mean change the wires of each motor , but swap left to right motor.
                            davidewen @peter247
                            @peter247
                            Again, that would give me the same results, but with added effort of changing code.
                            I've done a little more testing. This time by phyiscal force.
                            I manually moved the X / Y axis and watched the motor directions.
                            X - both motors move in the same direction
                            Y - motors move opposite of each other
                            So, somehow I need to figure out how to make Duet do the same.
                            • peter247undefined
                              peter247 @davidewen
                              @davidewen Yes , mine is in the same direction on both motors .
                              But you still may need to swap motors .
                                Check out these two posts they might help you get things straightened out.
                                https://forum.duet3d.com/topic/14971/vcore-pro-core-xy-the-x-and-y-axis-home-issue/4
                                https://forum.duet3d.com/topic/12676/mirrored-x-axis/9
                                The gist of it is to choose where the front of your printer is when looking at it straight on. 0,0 is the front left corner. X+ moves to the right, X- moved to the left, Y+ moves to the back, Y- moves to the front. That is the way it should be. If it's not like that yet, don't worry, we will make it that way. this is to match the slicer and CAD coordinate systems.
                                Then your endstop location is fixed either at the low end or high end of travel. That determines your M574 commands.
                                Then your homing directions will be positive or negative o move the head towards the endstops.
                                Now with all that fixed you can do the motor direction test in the corexy setup guide to determine what to do next.
                                  davidewen @Phaedrux
                                  @phaedrux
                                  Thank you for your help.
                                  Sorry for my delayed response. I was on vacation last week.
                                  Ender 6 physical setup
                                  X & Y motors @ rear
                                  X & Y stops @ max
                                  NOTE: I had to swap X & Y at the Duet board to get the correct movement.
                                  I have the X & Y axis moving correctly per your referenced link
                                  X homes correctly.
                                  Y homes correctly.
                                  Thanks again!
                                  David
                                    Just to double check, try printing some text to see if anything is mirrored.
                                    davidewenundefined 2 Replies Last reply Reply Quote 0
                                      davidewen @Phaedrux
                                      @phaedrux
                                      I'm not to the point of printing yet. I don't even know how to load a file yet.
                                      I'm still trying to figure out the rest of the config.
                                      I'm currently working on the Extruder.
                                      I installed a Bondtech extruder. So far it's working, but not loading filament all the way, so I must have some parameters incorrectly set.
                                      So far I have the X, Y & Z axis moving in the correct directions and the endstops working.
                                      The EZAble seems to be around 15mm off to the + side even though I have it set to +2mm.
                                        davidewen @Phaedrux
                                        @phaedrux
                                        First print completed.
                                        I printed text to confirm no mirroring was happening.
                                        I had 2 problems.
                                        1: 1st layer was crushed against the build plate. I had to babystep by 2.8 mm to get filament to come out. Homing Z works everytime. I used Cura to slice.
                                        2: print was horribly slow. It took 38m 27s to print "Duet 3 mini 5+" @ 0.6mm thickness.
                                        I'm using mesh compensation, and it maps out the surface.
                                        Printer is capable of moving 200mm/s.
                                        Any suggestions for solving these 2 problems?
                                          Phaedrux Moderator @davidewen
                                          @davidewen said in Need help with Ender-6 core xy motor movement:
                                          Calibrate your probe offsets.
                                          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                                          Check your cura start gcode section for any speed commands that may be there overriding your config.g settings. Also make sure you're set to use RepRap Gcode flavour.
                                          Post a sliced gcode file here if you're unsure.
                                            davidewen @Phaedrux
                                            @phaedrux
                                            Thanks. I'll calibrate the probe offsets.
                                            I'm not sure about the RepRap flavor.
                                            Here's the gcode that I ran.
                                            Duet 3 mini 5.gcode
