    Finer Z Movement Controls during Manual Calibration
    Duet Web Control wishlist
    1
    1
    409
    • fcwiltundefined
      fcwilt
      On my deltas I use the manual calibration feature of 1.19.x with a dial indicator replacing the hotend.
      The indicator is accurate to 0.0005"
      The current up/down "jog" buttons displayed are +/- 0.1mm which works out to about 0.004" - which is more coarse than the indicator is capable of.
      If a printer with 1.8 degree stepper motors is capable of meaningful finer resolution I would like to see two additional "jog" buttons using a smaller step size more in line with the capabilities of the indicator - perhaps +/- 0.01?
      Thanks you.
