    RepRapFirmware 3.3 upgrade issues
    Firmware installation
    • Handymanpa54undefined
      Handymanpa54
      Hello All,
      Do I need to modify config.g to get RepRapFirmware 3.3 to work? When rebooting to this software I loose connection to DWC?? So I dropped back to RepRapFirmware 3.2 and all is ok.
      Mark
      engikeneerundefined 1 Reply Last reply Reply Quote 0
      • engikeneerundefined
        engikeneer @Handymanpa54
        @handymanpa54 DWC is hosted on the Duet, so if you reboot it will drop connection, but should reconnect within a few seconds. Is that what you're seeing?
        i3 clone with a bunch of mods
          How are you doing the firmware update?
          When you're using 3.2 and have access to DWC upload the full 3.3 zip file to make sure you have everything updated at once.
